weight of posts
Started by tesa, January 28, 2009, 10:07:35 PM
tesa
daniel and i are very close to building our RV cover
by the way, thanks to all those who helped with the design
wondering if anyone might know the weight of a 20 foot 4x6 post?
i tried to poke around the net, and i found a calculator based on boardfeet, and it said 120lbs.
i guess that just seemed a bit light
but hey, i've never worked with such things before, so i thought i'd
ask those in the know
tesa
"building a house requires thousands of decisions based on a million bits of information"-charlie wing
rwanders
120 sounds about right----but actual weight will vary some due to differences in the density of species of tree and moisture content.
tesa
thanks! so you think three grown-ups in fairly good shape could get one in the ground?
well, actually 10, but if we can do 1, we can do 10
tesa
rwanders
Two cautions:
Be prepared to let go and move quickly if it begins to get away from you and;
Might be wise to attach one or two 2x4 braces at least to the first one to help provide leverage while you are lifting and also to hold it plumb after you get in the hole.
fishing_guy
Quote from: tesa on January 28, 2009, 10:22:08 PM
tesa
In my experience the first post will be the lightest...the last post will be the heaviest...
But take your time...and be prepared to bail if it gets away from you.
lonelytree
Wear gloves. Those splinters hurt and can become infected.
Good luck,
Mike
One trick if you don't want to rig the post and lift vertically to drop it in a hole is to put a couple of boards down into the hole opposite the side you are bringing it in from. the foot of the post can then ride down the boards rather than digging into the soil and ending up with loose dirt under the post on your footings. My wife and I have been installing 12 foot black locust 6x6's the last couple of weeks around the garden. About that weight but much shorter, its been doable but it sorta resembles work. Dang long legged mice  ;D.
tesa
thanks everyone!
i'm actually gonna lay low on that project, its husband, and two very strong friends,
tesa
