basic wall framing
Started by dogneck, September 18, 2008, 12:09:53 PM
dogneck
Quick question.  Most all of my walls are done.    I am finding on the last one that when trying to decide on where to put the 2x3 window and a 14 1/2 to 42 1/2 rough opening for heating unit,  that with the trimmer studs and the placement, I end up with a small gap next to the next 16" o/c stud.  Should I just move it over or put another stud in there also?
Also (already done)  I have a large rough opening for a sliding glass door.   It is on the 14' side of a 14x24' building.  This is considered a non-bearing wall.  (???)   The header I made from 2x4 with 1/2 plywood spacer.   Do I need to do this again and put in a 2x10 double header.       What about the header for the heating unit that would be on the bearing wall 42 1/2" long?
Quote from: dogneck on September 18, 2008, 12:09:53 PM
If you simply move it over that would throw off your nailing pattern for any sheet goods inside or out, especially if it falls on a 4 foot multiple. Why not leave the space and insulate it? IMO, that's better than inserting an extra stud. I have a couple like that, one will be fitted carefully with fiberglass and the other has been treated to foam in a can.
The header in the non bearing end wall should be fine in a single story wall; not sure if having an upstairs (1/2 story or full) wall would change that. A loft should be okay.
Any opening in a load bearing wall should have an appropriately sized header. The load on the wall doesn't discriminate between a door, window, heater or air conditioner.
dogneck
Thanks, that is what I'll do.   I'll have to put a big header over the 42" span. d*
