Little House Plans / Stairs
Started by APG, December 11, 2006, 02:35:23 AM
APG
Could stairs be incorporated into LHP? My though was to do a full loft or would it be a second floor (L and R at the top of the stairs.  This would create two lofts areas.  The larger for sleeping would be over the living area - the smaller for storage would be over the bath and kitchen.  I was thinking of doing 10" walls - which would give me more headroom in the loft area.  Eight foot ceiling on the first floor would be fine.  I'm undecided, but I could go with 9' ceiling on the first floor.  I'd appreciate your comments and suggestions.  Thanks much!
Dimitri
#1
Why not! If you can fit it without taking up too much floorspace you could fit in anything you wanted really even a indoor spa!  :o
Dimitri
#2
The Enchilada plans set has a detail for a taller roof (using 12' studs) that gives more room to the loft. This set also includes a cottage stair that can be used to get to that bigger loft. That stair doesn't take as much room as the standard "U" shaped stair (normally about 6 1/2' x 8').
Those plans are for an upgraded 14x24 Little House. Several folks have built that version. See the Victoria Cottage photos where this owner did the Builders Cottage as a guest house/rental out back - http://www.countryplans.com/vc.html (This version was built with 10' studs so the loft would be taller with the 12" wall shown in the plans.)
