Side exit vent stack
Started by Bouncer, July 14, 2006, 11:23:23 AM
Bouncer
Well I installed the side vent stack. I went this way instead of going threw the roof. I have a fear of cutting my metal roof. I think it looks good. We have no codes around here so It's not a problem here.
And for some reason it doesn't work out I can just remove the cap put an elbow and run the stack up.
Kevin
bartholomew
I think going through the wall makes a lot of sense -- why introduce potential leak points into your roof if you can avoid it? I looked into sidewall venting once and the main concerns seemed to be....
- Sewer gases might flow along under the soffits to nearby windows.
- With a horizontal terminus, wind could blow directly in and blow water out of traps.
Okie_Bob
To solve the problem mentioned by Bart...put a 'studer' valve on the top of your vent. It is like a check valve
that allows air in but does not allow sewer gas out! They are used a lot in island kitches where you need a vent but have no way to get to your normal vent stack. They are cheap and come in various sizes for pvc pipe. You may have to go to a plumber supply store to find them.
Okie Bob
Kevin
Bart
Thats why I have a cap at the end to keep anything from going in  like the wind or animals.
Careful what you recommend, Bob--- now you have my wife wanting to fit me with one of those studer valves. :-/
bartholomew
QuoteThats why I have a cap at the end to keep anything from going in  like the wind or animals.
Yes, both issues seem to have pretty straightforward solutions, so I wonder why it seems that most codes don't allow sidewall venting.
It seems that the studer valve is a last choice preference for the inspectors - I remember years ago talking to one about it and seems he didn't like it if there was any other way.  Maybe because it was mechanical.  I don't know what current code says about it.
