Medeek Floor Plugin
Started by Medeek, December 06, 2019, 11:43:25 AM
Medeek
Tutorial 18 - Moving Walls with Floors (9:17 min.)
Nathaniel P. Wilkerson, P.E.
Medeek
Version 0.9.9s - 11.13.2024
- Added the "Open Joist" floor family.
- Added the following TriForce Open Joists: OJ3-11.875, OJ4-11.875.
Medeek
Various configurations and example usages of top-bottom and bottom-top for open web (Redbuilt) and steel trusses (K Series):
Medeek
Version 0.9.9t - 11.19.2024
- Added the "Open Web" floor family (RedBuilt™: Red-L, Red-M, Red-S, Red-M, Red-H).
- Added the following TriForce Open Joists: OJ3-14, OJ4-14, OJ3-16, OJ4-16.
- Added the "Steel Truss" floor family (Nucor®: K-Series).
- Added a removal parameter for sill plates.
Medeek
Version 0.9.9u - 11.23.2024
- Added the "CFS" floor family: ClarkDietrich, JoistRite and TotalJoist.
- Added additional logic for non-standard joist sizes for Open Joists (TriForce).
- Addressed some minor bugs with metal bracing and other advanced options for top chord bearing trusses (Open Web and Steel).
- Added a built-in steel material option for rim joists.
Let me know on any other floor framing system(s) that I should add.
Medeek
Version 0.9.9v - 11.24.2024
- Added a "Web Shield" option for PinkWood (PKI) I-Joists.
- Fixed multiple bugs with the floor preset module.
- Fixed a bug related to metric units within the edit menu.
- Updated (Manufacturers: LP and PinkWood) links on the Floor plugin website.
They now have this new option called "WebShield":
Medeek
Version 0.9.9w - 11.25.2024 thru 11.29.2024
- Fixed multiple bugs with metric units within the attribute libraries and edit menu.
- Fixed a bug with offset joists and metal bracing, blocking and insulation.
Medeek
Medeek
Version 0.9.9x - 12.01.2024
- Fixed a bug with the SUBTRACT_JOIST feature.
- Updated the algorithm for large span Open Joist floors.
Rather than insert a fictitious joist size that does not actually exist I decided to insert two short joist products back to back.  This seems to be the typical way to handle large span floors with this product (similar examples are given in the product literature).  This update was also by customer request.
The update to the SUBTRACT_JOIST feature is a critical update and I highly recommend updating to this latest version if you are using that functionality.  Since the boolean subtraction of the joists happens before the final floor assembly is created I had to account for the pre-transformation of the joist geometry and include this within the subtraction method.
Medeek
Version 0.9.9y - 12.04.2024
- Added Steel Decks w/ Concrete Slabs (Verco®): B-36, N3-32, W2-36, W3-36, SV, DV.
Medeek
Tutorial 20 - Steel Decking (8:19 min.)
Medeek
Version 0.9.9z - 12.07.2024
- Added Roof Sheathing within the Advanced Options.
- Added the following membrane types to the Roof Sheathing Module: BUR, MB, TPO, EPDM, PVC.
- Enabled multi-ply insulation with the roof sheathing module.
Medeek
Tutorial 21 - Roof Sheathing (7:13 min.)
Medeek
Version 1.0.0 - 05.10.2025
- Enabled an edge material/texture for LSL rim boards.
- Fixed a bug with diagonal deck boards for large aspect ratio decks/floors.
- Fixed a number of misc. minor bugs.
- Added the following steel deck profiles: 2.0D, 3.5D, BCD-36, N3CD-32, W2CD-36, W3CD-36.
The floor opening tool and the MPC wood trusses are still pending so I really don't want to call this Version 1.0.0 but I also really need to get some bug fixes out the door and some other minor updates and I've run out of letters in the alphabet.  In the next couple of weeks I'm hoping to devote all of my time to these two big items and see if we can actually knock them out this time.
I'll be the first to admit that I am spread a bit thin with all of these plugins.  I've been bouncing back and forth between the Wall and the Truss plugins for the last couple of months but now the Floor plugin needs my attention.
Medeek
Version 1.0.1 - 05.18.2025
- Added floor openings with fully customizable headers.
- Added the floor openings toolbar with the following five items: Draw, Move, Edit, Regen and Delete.
Medeek
Medeek
I've been giving the feedback I received thus far on the new opening tool some serious thought  and after further testing I can see that adjusting the header extensions to reach out and grab the correct joist is probably the biggest bottle neck in the process, if you can call it that.
Below is an example of a six sided L-shaped opening in a floor.  It has three headers and three "trimmers".  Note that headers run perpendicular to the joists however the opening tool really makes no distinction between headers and trimmers, they all have the same ten parameters.
I had to make five entries to adjust the headers to meet the I-Joists as shown.  Really not that difficult but somewhat time consuming and tedious in my opinion.  The solution to this problem could be to have the plugin somehow detect the nearest joist and auto-extend to it.  However, I feel that such an algorithm would be overly complicated and probably not very robust.
The other option would be to create a "Header Stretch" tool that allow the user to simply mouse over the header, select one end or the other and then stretch it to the desired location.  This tool would be very similar to the "Wall Stretch" tool that is part of the Wall plugin.  Rather than navigating through the labyrinth of menus one could simply adjust each end with only three mouse clicks.
Again, I have my work cut out for me.
I've also realized that it is not readily apparent to the user which header is which.  I may need to incorporate some sort of labeling option that will assist with this.
Medeek
The Floor Opening toolbar will now contain a sixth tool called "Stretch Header" which will allow the user to stretch the opening headers in a more intuitive fashion:
I'm not really wanting to add more icons to my already bloated toolbars but I feel like this will be a very worthwhile tool and it will almost certainly makes everyone's life a little easier when it comes to these openings.
Medeek
Version 1.0.2 - 05.22.2025
- Enabled multi-ply floor headers for openings.
- Enabled variable lengths for staggered joists.
You can now enter in a single value for the joist length or you can enter in a list of lengths deliminated by commas. This update per user request.
Medeek
Version 1.0.2b - 05.23.2025
-Updated the joist removal function for more granular usage when working with staggered joists.
I apologize for all of these micro updates, I would have preferred to roll this out after adding a few more features etc... However, the user who requested this specific ability obviously needs it to complete their project so it is simply a matter of expediency.
Now one can not only specify a single line of joists to remove but also remove specific joists from a given line, see screenshot above and note the syntax in the Remove Joists field.
Medeek
Version 1.0.3 - 05.25.2025
- Enabled I-Joist floor headers for openings.
Medeek
Version 1.0.4 - 05.26.2025
- Enabled joist hangers for openings.
Tutorial 24 - Joist Hangers and Openings (7:58 min.)
Medeek
Version 1.0.5 - 05.30.2025
- Added the ability to stretch opening headers with the "Stretch Floor Header" tool.
Tutorial 25 - Stretching Opening Headers (7:50 min.)
Medeek
Version 1.0.6 - 05.31.2025
- Added an edit function to the "Stretch Floor Header" tool.
- Added a "Timber" header type for floor openings.
- Fixed minor bugs in the floor opening module.
Medeek
Tutorial 26 - Editing Opening Headers (5:00 min.)
