Medeek Floor Plugin
Started by Medeek, December 06, 2019, 11:43:25 AM
Medeek
Looks like I'm about 95% there with floor trusses:
The only issue appears to be what happens when ribbon boards are enabled and you have an inside corner as shown. I probably need to add in some additional logic to eliminate the slot for the ribbon board in these cases.
Nathaniel P. Wilkerson, P.E.
Medeek
Version 1.0.7 - 06.06.2025
- Enabled MPC Wood Trusses with ribbon boards, multiple chases and gable trusses.
- Updated the Move Floor Edge tool so that it also toggles the metal plate connector layer.
- Update the SUBTRACT_JOIST feature so that it can adequately handle MPC wood trusses.
Tutorial 27 - MPC Wood Trusses (13:25 min.)
Medeek
Version 1.0.8 - 06.08.2025
- Updated the SUBTRACT and SUBTRACT_JOIST features so that they can better handle MPC wood trusses, steel trusses and open web "Redbuilt" trusses.
- Updated the Floor Opening module so that it can handle MPC wood trusses, steel trusses and open web "Redbuilt" trusses.
- Added a "None" option for the header type in the draw and edit menus for floor openings.
Medeek
In many cases when you introduce a stairwell opening into  a floor like this it will be along the perimeter of the floor assembly as shown.  In these cases it is simpler to create your floor perimeter with the opening in mind:
Note, in order to create the additional gable truss (2x6 ply) I first changed my ply width to 5.5" then copied the gable truss at the interior of the stair well, then pasted it in place in the root of the model and then edited the floor assembly back to the typical 3.5" ply width.  Alternatively one could simply frame this small pony wall with the Wall plugin (ie. conventional framing) just as easily.
I'm not exactly sure how the trusses would work where the LVL beam/header is positioned at the start of the stairwell, obviously we would need some kind of header at that location.
Here is a link to the model for those who are interested in examining this floor truss example in more detail:
https://3dwarehouse.sketchup.com/embed/62200e55-7a11-4b43-bdac-4d00119d4f01?token=4RdrisG1fJM=&binaryName=s21
Medeek
Version 1.1.0 - 12.11.2025
- Updated the file/component loading method for hangers and certain joist types to increase plugin performance.
- Fixed multiple bugs with CFS joists.
Medeek
Version 1.1.1 - 12.15.2025
- Added the following face mount Simpson hangers into the built-in library: THA422, THA422_2, THAC422, THAC422_2.
- Added the following top flange Simpson hangers into the built-in library: WP48, WP410, WP412, WP414, WP416, HWP156, HWP356.
Medeek
Version 1.1.2 - 01.02.2026
- Fixed bugs with saving floor presets
Thank-you to all those who are sending in bug reports.  Please keep sending those in, they are very helpful and I am able to track down and put out the little fires that much more quickly.
If you think you have encountered a bug, turn on the Ruby Console in SketchUp, then duplicate the behavior and then send me any error codes generated with other pertinent details.  I will do my best to remedy all bugs that are detected and reported.
Medeek Engineering
Version 1.2.2 - 07.19.2026
- Added a floor "profile" edit tool within the context menu for floor assemblies.
- Added a "Grid Snap" option with hotkey (End key) into the floor profile edit tool.
