Wall Plugin for SketchUp
Medeek
Tutorial 76 - Double Stud Walls (18:03 min.)
Nathaniel P. Wilkerson, P.E.
Medeek
Tutorial 77 - Mitek vs. Simpson (11:00 min.)
Medeek
Version 4.1.8 - 12.13.2025
- Fixed a long standing bug where blocking was not created above and below doors, windows and garage doors.
- Fixed the blocking bug for rectangular, gable, shed and hip walls.
- Fixed a context menu bug (Edit Opening...) for gable, shed and hip walls.
Medeek
Version 4.1.9 - 12.16.2025
- Enabled the "Add Studs" feature for the following wall types: rectangular, gable, shed and hip.
Tutorial 79 - Adding Studs (5:31 min.)
Medeek
Version 4.1.9b - 12.18.2025
- Fixed a bug (door presets) introduced with door hardware material update on 11/29/2015 (Version 4.1.5).
Medeek
Version 4.2.0 - 12.22.2025
- Updated the opening and closing algorithm for all (panel) garage doors.
Not a customer request, just an interesting kinematic challenge that I felt like addressing at some point.  I found the previous garage door opening animation largely unsatisfactory for panel doors like these.  Hopefully you can indulge me with a little gold plating... now back to the real stuff.
medeek1972
Version 4.3.3 - 02.08.2026
- Added the following Simpson Strong-Tie anchor bolts to the wall, column and shearwall modules: SABR58-24, SABR34-26, SABR78-28, SABR1-30, SABR114-32.
These new anchor bolts are included in the new Wood Construction Connectors Catalog (C-C-2026) for 2026.
https://www.strongtie.com/bolts_anchorbolts/sabr_bolt/p/sabr
These low poly versions of the anchor bolts are based on the models provided on Simpsons website.
