Wall Plugin for SketchUp
Medeek
I suppose one could gang together as many window units as one would like, but two or three is probably the practical limit from a structural standpoint.
Here is a three-gang of windows with one header, utilizing the recent advanced framing options:
Nathaniel P. Wilkerson, P.E.
Medeek
Version 4.0.0b - 05.28.2025
- Enabled "green" pressure treated lumber within the stair module.
Medeek
Version 4.0.1 - 05.29.2025
- Added five additional layers to the Layers tab of the Global Settings for stair assemblies.
- Added a "Stair Layers" option into the Layers tab of the Global Settings in order to toggle the stair layers "On" or "Off".
Tutorial 71 - Layers/Tags for Stairs (4:02 min.)
Medeek
Version 4.0.2 - 06.01.2025
- Added a bottom gap parameter to the draw and edit menu of the door module.
- Added the bottom gap parameter to the door tab of the global settings.
Medeek
Version 4.0.3 - 07.03.2025
- Fixed a long standing bug (06/27/2023) with the edit dimension tool for framing dimensions (rectangular walls).
