squash blocking
Started by busted knuckles, July 02, 2016, 11:11:18 AM
busted knuckles
between joists for ridge beam support. stand lumber on end? or on edge? Thank you in advance.
I'm assuming these are carrying a post from ridge to subfloor and are standing on end under the subfloor and running down to a girder or wall. If so stand them up on end, cut a hair longer than the joist is tall... they take the point load squash rather than the I joist. Under sliding door or similar sized header supports as well.
