This may be a silly question (VC plans)
Started by misspriss, January 29, 2016, 10:30:54 PM
misspriss
Okay, just got my VC plans and I'm super excited. This is the first time I've bought house plans or tried to build a house, so if this is just one of those things I should know I apologize.
Everything in the plans says it is spruce, and we got the materials list too and it says spruce. I'm pretty sure everything I see for sale around my area is pine, is that a problem? Do I need to get special studs or are the pine studs I get locally fine? Should I note it on the plans (they say spruce) when I go to get permits? Does that matter? thanks!
The species (pine, spruce, S-P-F, DF, etc) does not matter as much as the lumber grade, stud grade, #2, #1, Select, etc.   You will see things like "Top Choice" that are simply marketing names and mean nothing.
This link is to a southern pine specific grading rules page that may be of interest. You can always substitute a grade that is higher on the list for one that is lower on the list, but noth the other way around without making allowances for the lesser strength of the grades father down the list.
misspriss
Thanks that is exactly what I needed to know!
Where it might make an issue is when plans are drawn and certain trim is called for such as ceder trim boards or red wood.  That has nothing to do with structural strength but ability to withstand weather and solar damage....  my two cents worth.... ;)
In the General Notes on page 1 of the plans the sawn lumber is called out for as Hem-fir and Doug-fir #2 or better. That can be changed to the normal construction lumber for your area. The lumber yard can give you substitution advice.
