Author Topic: Woodburning Stove and Spiral Stairs  (Read 2418 times)
Offline Homesick Gypsy
  • Junior Member
  • CountryPlans member
« on: November 11, 2009, 10:37:38 AM »
I'd like to put a metal spiral staircase up to the loft - I'm figuring 48 - 52 inches for the footprint.  Here's the question, can I put a woodburning stove at the base of the stairs and run the pipe up parallel to the center support pole of the stairs?  Could I insulate the stovepipe or possibly run a chimney up the same way?
Offline MountainDon
    • My 15.75 x 30 Jemez Cabin
Re: Woodburning Stove and Spiral Stairs
« Reply #1 on: November 11, 2009, 10:56:06 AM »
If the chimney pipe would be close enough for anyone to somehow accidentally touch the pipe from the staircase I believe insulated pipe should be used. Black pipe can produce an instant burn at times.
The use of long lengths of insulated pipe would shoot the chimney costs through the roof but would be safer. There would be a side benefit of maintaining the inner temperature of the flue better with less creosote ormation as a result. A trade o is that using black pipe will radiate more heat to the interior.
« Last Edit: November 11, 2009, 11:42:40 AM by MountainDon »
Offline Squirl
« Reply #2 on: November 11, 2009, 11:26:24 AM »
I have seen it done on the green network.  I believe the show was renovation nation.  I always laugh because the "green" homes they tend to showcase are usually over 10,000 sq ft and cost in the over $1,000,000 price tag. IIRC, it was a southwestern U.S. house done by an author.  It was an insulated stove pipe through the center of the spiral staircase.  Hopefully that helps you find it.
Offline MountainDon
« Reply #3 on: November 11, 2009, 11:43:10 AM »
Ya gotta wonder about those mega dollar green homes.
  • Junior Member
« Reply #4 on: November 11, 2009, 02:43:04 PM »
Thanks guys.  Squirl, I looked but couldn't find it on Renovation Nation.  It might be there but their website is moving like a herd of turtles through molasses and I don't have the patience for it today.   [waiting]
Offline MikeT
  • "The best is the enemy of good." Voltaire (1764)
« Reply #5 on: November 14, 2009, 05:47:18 AM »
If you use a double wall stove pipe, you can get by with 9" of clearance, I believe.
Offline Jens
  • Knoxville, TN
    • Tikkun Construction
« Reply #6 on: December 21, 2009, 06:19:59 PM »
those shows make me sick, but they do have some good ideas and suggestions.
Offline OkieJohn2
  • Full Member
« Reply #7 on: December 23, 2009, 12:39:16 AM »
Have you noticed how often the so called "green" shows just throw away lots of stuff, just to replace it with "green" products.
Cache hits: 12: 0.00205s for 40,806 bytes (show)
Queries used: 28.
