Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Forum
Help
Search
Login
Register
CountryPlans Design/Build Forum
General
General Forum
(Moderators:
hpinson
Adam Raabe
CP office closed Wed for three days
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: CP office closed Wed for three days (Read 3824 times)
Administrator
Journeyman
Whidbey Island, WA
on:
June 13, 2005, 11:29:52 AM »
The CountryPlans office will be closed this coming Wed, Thurs & Fri (6-15,16,17). If you want to order plans that will get to you quickly, please have them ordered by close of business Tues 6-14.
Otherwise they will be filled and shipped on Monday 6-20-05.
Thanks, John
PS - I am picking up an older RV and will be testing it out with a plan of being able to research small houses while on the road. I will be attempting to post some pictures and an update to this forum while traveling. We'll see how it goes.
Last Edit: June 13, 2005, 11:30:40 AM by jraabe
Logged
DavidLeBlanc
Senior Member
Seattle, WA - the Emerald City
Re: CP office closed Wed for three days
Reply #1 on:
June 13, 2005, 11:36:10 AM »
If you're coming through Seattle, there's a very interesting little development at the corner of 15 or 16 and Jefferson (off the James St. exit, across from the old Providence Hospital, if you know the area).
4 Cottages on a standard (for Seattle) corner lot. Very cute little places: large room downstairs with kitchen at one end, plus a 1/2 bath tucked under the stairwell. Upstairs are 2 bedrooms, full bath and laundry facilities. "Ross Chapin for the working man". I heard they sold in the $80k's.
Logged
The Troglodyte
Administrator
Journeyman
Central California Sierras- Home of Yosemite NP
Reply #2 on:
June 13, 2005, 06:10:42 PM »
Good luck , John. Maybe I'll see you here sometime if it works good
I also will be a bit swamped for the next couple days working out of town, but will try to pop in a bit morning and night.
Last Edit: June 13, 2005, 06:11:09 PM by glenn-k
Logged
Glenn's Underground Cabin
http://countryplans.com/smf/index.php?topic=151.0
Administrator
Journeyman
Whidbey Island, WA
Reply #3 on:
June 14, 2005, 05:33:07 AM »
I would love to stop and visit some of the fine folks I've met on this forum but that will have to be another better planned trip.
This will be a shakedown cruise up the spine of the Colorado Rockies into Wyoming, (maybe over into Utah if time and weather permit) then Montana, Idaho and Washington.
This is the vehicle — she seems well cared for and the ebay seller is honest... but this is a 1978, so wish me luck! (eBay item #4554595160)
Last Edit: June 14, 2005, 05:47:58 AM by jraabe
Logged
craig lauer
Guest
Reply #4 on:
June 14, 2005, 07:37:52 AM »
david
any pictures of the "working mans houses you discribed ?
Logged
DavidLeBlanc
Senior Member
Reply #5 on:
June 14, 2005, 07:47:57 AM »
Alas, not at the moment - my camera is unavailable.
They do not look to be too different in size from a Builder's Cottage, except that they're a full 2 stories.
Narrowish staircase runs up the back side of the long axis, possibly with an "el" near the top. I didn't get to see the upper floors directly.
Logged
Epiphany
Guest
Reply #6 on:
June 15, 2005, 11:15:23 AM »
David, can you find out who the builder was of the small homes on Jefferson? I just found an article in the March 24, 2005 Seattle Times called "Shoreline Cottages - Too Close For Comfort? in which "cottage housing" seems to be pretty unpopular with its existing neighbors. It mentions the four cottages on Jefferson as an experiment.
Last Edit: June 15, 2005, 11:27:17 AM by Epiphany
Logged
DavidLeBlanc
Guest
Reply #7 on:
June 15, 2005, 02:18:28 PM »
I'll see what I can do about finding out who designed the Jefferson St. project.
The Shoreline cottages project was done by Ross Chapin through his "The Cottage Company". Interesting to hear negative feedback.
Logged
DavidLeBlanc
Guest
Reply #8 on:
June 15, 2005, 02:32:29 PM »
Have a look @
http://www.homesteadclt.org/issue20.pdf
Built by Shelter Real Estate Developments.
Architect: David
More info by emailing nicehouse@comcast.net
As you can see in the illustration in the above .pdf file link, it's more accurate to call them 1-1/2 story cottages. Craftsman style detailing.
I'm APPALLED at the price, although, they are still less than 1/3 of what Chapin's new stuff is going for - $500,000+ (slightly larger than cottages under discusion, to be fair).
Logged
jonseyhay
Guest
Reply #9 on:
June 16, 2005, 12:27:16 AM »
John,
Is there a book hatching here, or are you going to be one of those Grey nomads.
jonesy.
Logged
Print
Pages: [
1
Go Up
« previous
next »
General
General Forum
(Moderators:
hpinson
Adam Raabe
Templates: 5:
index (default)
Ads (default)
Portal (default)
Display (default)
GenericControls (default)
Sub templates: 12:
init
html_above
adsheaders_above
body_above
adsindex_above
portal_above
main
portal_below
adsindex_below
body_below
adsheaders_below
html_below
Language files: 3:
SPortal.english (default)
index+Modifications.english (default)
Ads.english (default)
Style sheets: 1:
portal (default)
Files included: 38 - 1132KB. (
show
./index.php
./Settings.php
./Sources/QueryString.php
./Sources/Subs.php
./Sources/Errors.php
./Sources/Load.php
./Sources/AnnoyUser.php
./Sources/Subs-Portal.php
./Sources/Security.php
./Sources/LoadAds.php
./Sources/Subs-Db-mysql.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-modSettings.php
./Sources/ManageSearchEngines.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-spider_search.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-board_parents-0.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-permissions--1.php
./Sources/Subs-Auth.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-theme_settings-1.php
./Themes/default/languages/SPortal.english.php
./Themes/default/index.template.php
./Themes/default/languages/index.english.php
./Themes/default/languages/Modifications.english.php
./Themes/default/Ads.template.php
./Themes/default/languages/Ads.english.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-log_online-update.php
./Sources/PortalBlocks.php
./SSI.php
./Themes/default/Portal.template.php
./Sources/Display.php
./Themes/default/Display.template.php
./Sources/Subs-Editor.php
./Themes/default/GenericControls.template.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-verificationQuestionIds.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-parsing_smileys.php
./Sources/AutoEmbedMediaPro2.php
./cache/mediaprocache.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-response_prefix.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-moderator_group_info.php
Cache hits: 12: 0.00127s for 40,824 bytes (
show
get modSettings: 0.00018s - 15635 bytes
put modSettings: 0.00024s - 15635 bytes
get spider_search: 0.00009s - 1882 bytes
get board_parents-0: 0.00008s - 6 bytes
get permissions:-1: 0.00008s - 75 bytes
get theme_settings-1: 0.00008s - 2017 bytes
get log_online-update: 0.00009s - 0 bytes
get verificationQuestionIds: 0.00010s - 18 bytes
get parsing_smileys: 0.00012s - 5427 bytes
get response_prefix: 0.00009s - 11 bytes
get moderator_group_info: 0.00009s - 118 bytes
get menu_buttons--1-english-1: 0.00003s - 0 bytes
Queries used: 29.
