Author Topic: Work bench  (Read 1734 times)
Offline Chuckca
  • Full Member
  • I love YaBB 1G - SP1!
Work bench
« on: September 30, 2006, 11:44:22 AM »
My garage is full already...but I need a larger work bench and a table saw.  An idea hit me....build a work bench  that incorporates a table saw and a small drill press.  The bench would be 8-10'  long and 30" wide.  Anyone have ldeas where I can get FREE plans? Open to ideas.  Thanks!
Offline PEG688
  • Master Craftsman
  • Whidbey Island , Wa.
Re: Work bench
« Reply #1 on: September 30, 2006, 01:16:57 PM »
One of my cabinetmaker co worker / friend made his bench/ saw table . Basically he built IIRC 5 lower cab base's , figured out how wide / long/ high he wanted it . Your needs will vary , anyway 3 cabs on one side , two on the other with a lowered middle section that the saw fit into flush with the top . the top was two layer of High denisty particle brd , with a P-lam top with oak self edge , the top over hung all the way around so stuff can be clamped to it easely . The lower cabs where screwed to each other and had doors with shelfs in them. he made a sub bottom out of a peice of 3/4 plwood / 2x4 or 6's on the flat for added stiffness and put lock able wheels on the four corners so he could roll it around / outside on to the driveway when he had to .
 The drill press would be a problem but doable with some thought. Built right it was and is a solid work table / saw table etc . Not as solid as one with fixed legs but hey life is full of  compromise ;)My own fixed saw table is at 38" or so , higher than most but I'm 6'2" so it works well for me . BTW my other bench is slighlty lower , 1/2" so sheet goods can slide over when pushed thru the saw , but can be used as added support easly witha 1/2" shim when needed.
Offline Amanda_931
  • Glamorous Middle Tennessee
Re: Work bench
« Reply #2 on: October 02, 2006, 04:27:13 PM »
PEG wrote:
Quote
That might be a good idea for a sewing table as well.
Offline Jens
  • Knoxville, TN
    • Tikkun Construction
Re: Work bench
« Reply #3 on: October 04, 2006, 03:54:37 PM »
This months issue of Shop Notes has a good set of plans for one in it.
Cache hits: 11: 0.00196s for 40,688 bytes (show)
Queries used: 28.
