Medeek HVAC Plugin
Started by Medeek, June 28, 2025, 03:29:40 PM
Medeek
First look at the main assembly edit menu:
It seems like these menus always start off simple but then get overloaded with parameters. I will do my best to keep it simple but feature requests will ultimately dictate what form it evolves to.
Rectangular duct appears to be working as far as corners that "bend". I've still need to add in round and oval ducting, both of which should not be too much more difficult than square or rectangular ducting.
A few more editing tools to add (ie. segments, nodes, edge editing etc...). My youngest soon suggested that I also include a copy or eye drop tool similar to what is in the Wall plugin. I think this makes sense since it will be quite tedious to edit a bunch of segments or nodes and have to update them all separately.
I think it might also be useful to create a tool(s)which allows one to join or split an assembly into different assemblies.
After that I need to start adding in options for the nodes (ie. registers, boots, transitions etc...)
When creating a new duct assembly from a bunch of edges currently one has to select each edge by clicking on it. I think it need to update the tool so that one can drag a window and select the edges this way if desired. I've actually never programmed a "window selector" in any of my tools thus far so that should be interesting and maybe a little challenging.
Nathaniel P. Wilkerson, P.E.
Medeek
The same duct assembly switched to round and oval profiles:
I don't really see any other duct profiles being used than these three (Round, Rectangular, Oval).
In the next week I will be adding the "Edit Segment" and "Edit Node" menus/tools. Once those are complete I will need some beta testers to provide feedback and feature suggestions. If you are interested and can provide high quality feedback then I would be willing to issue you a license. Please be aware that this plugin is in no way ready for a production environment. I still need to clean up the global settings (borrowed from the Floor plugin) and a number of tools are still needing to be added.
Please email me (nathan@medeek.com) if you are interested. I probably will only issue about 10 licenses for BETA testers, I don't want too many voices at this point. My preference is that you are familiar with HVAC and you do some of this modeling within SketchUp.
Medeek
I'm debating whether to model the collar as shown. It does make the fitting more realistic but it does add some volume to the overall solid, which may affect my volume calcs if needed. I suppose I could figure out a clever way to calculate this out of the volume if it ever becomes an issue.
Thoughts?
Here is the start of the "boot" library:
4", 5", 6", 7", 8"
The naming convention is:
BOOT90_4X10X6_2
The last number indicates the vertical rise of the register box.
I think I have a enough now to start testing the component insertion logic.
Medeek
Drawing Fittings:
Editing Fittings:
The library is similar to the Electrical plugins system so one can simply add in as many pre-built custom fitting components as you like.
It would be really nice if I setup my fittings menus similar to the UK outlet and switch menus in the electrical plugin, so that they give you a small preview image. The question is how much work will this be to create.
Medeek
Oval, round and rectangular are now up and running:
Medeek
The following toolbar will be added for HVAC Appliances:
The HVAC Appliance tool will be for adding AC units, furnaces, fans, VAV's, boilers etc... Essentially any preconfigured HVAC equipment that is not duct work.
The will be simple stand alone assemblies that one can reposition using the native tools.
Medeek
Version 0.9.0 - 07.10.2025
- Created the Medeek HVAC Plugin, utilizing SketchUp's Ruby API.
- Added tools to create ductwork, fittings, and HVAC appliances (AC, furnaces, and heat pumps).
The BETA version is out, you can now download the trial version here:
http://design.medeek.com/calculator/sketchup/medeek_hvac_ext.rbz
Please be advised this is the very first release of the extension and there will be many fires to put out.
Tutorial 1 - Extension Overview (20.18 min.)
Medeek
After three weeks of non-stop coding I needed a break so I spent the day at the track (walking, I'm too old to run anymore) and then spent the evening digging up docs on Bryant furnaces. Surprisingly the dimensional data is quite accurate and thorough, here is the result:
Six actual models added, but really there are only three sizes (17.5, 21, 24).
I've been giving the calculations more thought and if I am able to incorporate that into the plugin then the BTUs, and other specs on these furnaces will also come in handy. I will probably need to create some sort of database or flat text file that has all the pertinent data on each furnace and the ability for the user to enter in custom furnaces and other appliances.
I always find that doing some low level modeling has an almost therapeutic effect. Maybe SketchUp is just such an fun to use and intuitive modeling environment, either way I find it to be a great way to relax and unwind.
Medeek
Version 0.9.1 - 07.29.2025
- Updated the draw and edit menus for HVAC appliances.
- Added the following brands and associated models into the HVAC appliance built-in library: Bryant, Rheem
