Author Topic: Few Questions on Concrete Pier Foundation (Probably beating a dead horse)  (Read 2894 times)
Offline ChugiakTinkerer
I was slow to come around to the general consensus viewpoint on pier contruction.  I think the permanent wood foundation is well suited for remote construction in Alaska.  Sometimes though the ground conditions call for a structure that floats on top of the ground, either to minimize permafrost thaw or allow for frost heaving.
Here's a recent cabin build in Alaska, I wonder if it might pass muster with the Dons.  :)
http://forums.outdoorsdirectory.com/showthread.php/150029-pads-with-posts-any-thoughts-from-those-experienced?p=1621770&viewfull=1#post1621770
Offline Don_P
Mostly yes. I've wondered why we don't see more steel pier and beam, you can actually make rigid moment resisting connections in steel. I would run a diagonal brace out of each corner in plane.
Offline akwoodchuck
  • Full Member
  • Homer, AK
I might be starting such a build here in a couple months....if so will try and post some pics and details....
Offline MountainDon
    • My 15.75 x 30 Jemez Cabin
Alaska is a special place; special for some of the natural wonders as well as needing some special techniques for a variety of things.
That looks like a nice special welded steel foundation.  Is it located near or in one of Alaska's earthquake-prone areas?  If so, how is it kept from falling off the jack stands?  It does appear that the foundation would hold together is shaken; I just wonder what the connection between jack stand screws and the upper section is.  ???
Offline JRR
  • 1000', Southeast, USA.
That foundation has a lot of bracing, but it all seems to be in one direction and none ninety degrees away.  ??
Offline goodasgone81
  • Apprentice
  • Welcome to the CP-Forum
Re: Few Questions on Concrete Pier Foundation (Probably beating a dead horse)
« Reply #30 on: December 09, 2018, 08:26:06 PM »
Soooooo I went with concrete piers, time will tell how it holds up.  That said it ended up being way "over engineered".  I used 32"w x 32"l x 22"h concrete forms with 16" sonotubes, buried 4' ..... with anywhere between a foot to 18" of that being in hard shale.  It was a rough digging all those by hand and took a lot longer than expected.  Followed up with having to carry in over 15,000lbs of concrete to mix, it's definitely not something I want to do again ha
Cache hits: 12: 0.00208s for 40,795 bytes (show)
Queries used: 29.
