Author Topic: VC Ridge Beam  (Read 1534 times)
Offline misspriss
  • Junior Member
  • Welcome to the CP-Forum
VC Ridge Beam
« on: February 06, 2017, 05:34:00 AM »
Quick question, I bought the VC plans and the materials list. We extended the length of the main 2 story section by 4'.
The plans call for a 5-1/8" x 16-1/2" x 28' Glu Lam Beam for that section, would I just get the same in 32', or will it need to be bigger because of the increased space? I didn't realize this would be an issue, I just thought "more of the same" was okay (I've seen that a lot on here) but now I'm concerned.
Also, I have seen people do multiple 1-3/4" beams fastened together instead of one, for easier handling, would that be acceptable?
Thanks!
Offline John Raabe
  • Whidbey Island, WA
    • CountryPlans - About Us
Re: VC Ridge Beam
« Reply #1 on: February 06, 2017, 12:20:51 PM »
Yes, the VC cottage is a little different from most of the other plans in that it was a custom house and is not as easy to expand as some of the simpler plans.
What I would recommend is checking with the lumber yard to see if they can supply a larger beam or come up with another solution for the extra 4' load. They may be able to assemble thinner beams into a larger section. They will be able to design for your local loads and can be more precise.
Best wishes, John
Offline misspriss
  • Junior Member
Re: VC Ridge Beam
« Reply #2 on: February 06, 2017, 02:58:01 PM »
Okay thanks. We don't have high loads here. We originally planned to do the alternate assembly with the trusses, but then all of a sudden like we are reconsidering the beam. I think the trusses will just be easier and we don't necessarily need the full height in the center.
Cache hits: 12: 0.01943s for 40,791 bytes (show)
Queries used: 29.
