Cutting your lumber with a Band Saw
Started by glenn-k, November 10, 2004, 11:54:22 AM
0 Members and 106 Guests are viewing this topic.
The chainsaw mill such as the Alaskan or others will make timbers and boards with a lot of work and a large kerf so a lot of waste, but has the advantage of machinery investment being relatively cheap.  I bought a bandsaw used for $3500 that will cut 20' logs and up to appx 30" diameter.  The kerf from most small bandsaws is 1/8" so there is very little waste.  I can cut clapboard  siding 1/2 inch thick or less if desired, accurately.  It will also cut as large a beam as will fit under the carriage and can be extended to any length by buying or fabricating more track sections.
Occasionally there are cheap used mills here
http://www.sawmillexchange.com/
or ask around your local area if you are in timber country.
A bit more expensive but well worth it if you have a need for lots of lumber. :D
Glenn
