What size of pipe for a water line from well to house?
Started by Erin, November 30, 2014, 03:37:25 PM
Erin
Flexible pipe, probably. You know, the black plastic stuff.
How big should it be, running 900 feet from well to a 2.5-bath, 4-bed house?
One inch? Inch and a half?
Erin I always use inch and a quarter.  Here on the ranch I keep a good selection of 1 1/4 fittings and clamps.  Tees - Elbows and Unions.  But you can not go wrong with inch and a half.  A lot less friction.   :D
Erin
hpinson
900 feet is a long run.  I see there are a number of online friction head loss calculators out there:
http://www.engineeringtoolbox.com/hazen-williams-water-d_797.html
Can someone who understands these work through an example with the 900 foot run of 1.25" ID black flexible poly pipe, and explain the results?
Tome
Quote from: Erin on November 30, 2014, 03:37:25 PM
In the big picture the price between 1" and 2" is not that significant when compared to the labor and equipment cost to install.  2" sdr 21 with a gasket will give you a little flexing and would be my choice. It's available at most water works stores.
SouthernTier
Quote from: hpinson on December 07, 2014, 07:11:58 PM
The pressure drop depends on how fast the water is flowing through the pipe.
I made a post on this topic a while back going through the math:
http://countryplans.com/smf/index.php?topic=12608.msg167943#msg167943
Note, this was using the Darcy–Weisbach approach, which is referenced as an alternate approach to the hazen-williams approach referenced above.  The linked web page says the hazen-williams approach is accurate for Reynolds numbers above 10,000, but you may not have that high a Reynolds number for cabin applications.
I didn't rerun the calculation for 1.25", but my calc was for 1" and a flow rate of 2.2 gpm and came up with a pressure drop of 0.00215 psi/ft, or about 2 psi over 900 feet.  It would be less with a larger diameter
