Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Forum
Help
Search
Login
Register
CountryPlans Design/Build Forum
Off Topic
Off Topic - Ideas, politics, humor, inspiration
(Moderators:
hpinson
Adam Raabe
220 outlets
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 220 outlets (Read 2769 times)
Journeyman
220 outlets
on:
December 17, 2012, 04:28:16 AM »
OK...I'm 220 outlet ignorant!
I want to use my welder with my generator. All my Generators have this outlet:
My welder needs this outlet:
Does anyone make an adapter or do I have to replace the plug?
Logged
diyfrank
Senior Member
Re: 220 outlets
Reply #1 on:
December 17, 2012, 05:06:02 AM »
Your generator takes the 30 amp L14 plug. You can buy a pig tail that your welder takes and put an L14 plug on the other end, if I understanding your question.
Logged
Home is where you make it
Journeyman
Re: 220 outlets
Reply #2 on:
December 17, 2012, 05:09:45 AM »
Yep, that's what I was looking for. Thanks !
Logged
Journeyman
Re: 220 outlets
Reply #3 on:
December 18, 2012, 12:37:32 PM »
I made a extention cord for my welder -- it is useful
you should use 10 GA 4 wire cable (expensive ) there are 2 grounds and 2 120 VAC legs on the generator plug
One ground should be an actual earth ground for safety (it is the green one inside the generator plug where you connect the wires)
"X" and "Y" are the 120 VAC L1 and L2
the other is W (for white I guess) that is the other ground used for the L1 and L2 lines
Logged
craig
Apprentice
Welcome to the CP-Forum
Re: 220 outlets
Reply #4 on:
December 19, 2012, 08:25:21 AM »
The W terminal on the 4-pin twistlock is the neutral. The G is the ground. You should only use the W terminal in 120 VAC applications. To hook up your welder plug on 220VAC, you should use the X and Y for the hot legs and G for the ground.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Off Topic
(Moderators:
hpinson
Adam Raabe
220 outlets
Templates: 5:
index (default)
Ads (default)
Portal (default)
Display (default)
GenericControls (default)
Sub templates: 12:
init
html_above
adsheaders_above
body_above
adsindex_above
portal_above
main
portal_below
adsindex_below
body_below
adsheaders_below
html_below
Language files: 3:
SPortal.english (default)
index+Modifications.english (default)
Ads.english (default)
Style sheets: 1:
portal (default)
Files included: 37 - 1132KB. (
show
./index.php
./Settings.php
./Sources/QueryString.php
./Sources/Subs.php
./Sources/Errors.php
./Sources/Load.php
./Sources/AnnoyUser.php
./Sources/Subs-Portal.php
./Sources/Security.php
./Sources/LoadAds.php
./Sources/Subs-Db-mysql.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-modSettings.php
./Sources/ManageSearchEngines.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-spider_search.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-board_parents-0.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-permissions--1.php
./Sources/Subs-Auth.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-theme_settings-1.php
./Themes/default/languages/SPortal.english.php
./Themes/default/index.template.php
./Themes/default/languages/index.english.php
./Themes/default/languages/Modifications.english.php
./Themes/default/Ads.template.php
./Themes/default/languages/Ads.english.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-log_online-update.php
./Sources/PortalBlocks.php
./SSI.php
./Themes/default/Portal.template.php
./Sources/Display.php
./Themes/default/Display.template.php
./Sources/Subs-Editor.php
./Themes/default/GenericControls.template.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-verificationQuestionIds.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-parsing_smileys.php
./Sources/AutoEmbedMediaPro2.php
./cache/mediaprocache.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-response_prefix.php
Cache hits: 11: 0.00159s for 40,731 bytes (
show
get modSettings: 0.00028s - 15641 bytes
put modSettings: 0.00035s - 15641 bytes
get spider_search: 0.00012s - 1882 bytes
get board_parents-0: 0.00015s - 6 bytes
get permissions:-1: 0.00010s - 75 bytes
get theme_settings-1: 0.00016s - 2017 bytes
get log_online-update: 0.00012s - 13 bytes
get verificationQuestionIds: 0.00009s - 18 bytes
get parsing_smileys: 0.00010s - 5427 bytes
get response_prefix: 0.00009s - 11 bytes
get menu_buttons--1-english-1: 0.00002s - 0 bytes
Queries used: 28.
