batteryless refrigerator
Started by Dave Sparks, July 03, 2012, 04:56:29 PM
Dave Sparks
This was the Nasa 2011 private sector product of the year. It is a little pricey now but perfect for someone who is too busy building to fool around with batteries, charge controllers, ect, and just needs to work on their house. A solar panel and 4 or 5 days of bad weather and the beer is still cold. 12/24V automatic
Don had said how much I like the Stecca units as they are freezer or reefer and automatic 12 or 24V.
It is getting easier out there off the grid!
http://sundanzer.com/wp-content/uploads/BFR105-Specs.pdf
hpinson
Wow. Have you seen it in action?
so to me thats just a standard 12V fridge with some extra cooling ballast, ie the plastic cool things for coolers
i run an Engle 45 fridge as my beer fridge in the house and for everything when offroading , exploring
When off roading etc for food I use it as a freezer, and turn off at night to conserve energy, and start again in the morning -everything is still frozen.
It consumes about 8 amps when running - so an 80watt panel and a battery gives you enough juice for continual operation
There are others too very similar some with better consumption than others
national luna- Engel - ARB are probably the best
Some offroaders have had luck with the with the cheaper edgestar - norcold copies
Mines 5 years old and running 24/7, I blew the original internal power board by plugging it into 220V and now just use a computer block supply now and run it on 12V
Native_NM
We put an Engel into the field to keep samples cold and the thing is amazing.  It was pricy at $900, but it sure does a good job.
Dave Sparks
Quote from: UK4X4 on July 03, 2012, 05:55:14 PM
Not really a standard as a battery is not required ! Soft start Danfoss compressor that drives directly off a solar panel.  If the sun does not shine for 5 days you are not spoilng food.  Also this is quite a bit larger capacity and it will run on any voltage up to 45vdc. This would allow one to use the reefer later when they have a house  electrical system built.
I like your system also, this is just modern engineering at work which is why NASA was impressed.
any of the fridges mentioned will run off a 130w panel- most use the same compressor as well engel being diferent has the fuji swing, luna the danfoss, the others are a mix
The refridgerated blocks are off the shelf, used in coolers and also enviromental enclosures in deserts, where they have vents opening at night taking on the cool temps then shut during the day with the blocks cooling the instrumentation cabinets
its also 104KG the equivalent sized Nat luna at 90ltrs weighs only 28kg the edge star 30kg
sundanzer says 80watt same as edgestar  only 7 amps but from experience on other forums usually higher
the natluna states 2.5 average running current  and its also 12-45v- running the same danfos compressor
heres a review of some of the common ones
http://www.expeditionportal.com/resources/equipment-review-and-testing/556-overland-journal-portable-12v-fridge-review.html
Most are 100-22v capable too, even Engle has changed in their later versions to staop what I did to mine.
If I had to choose- I would go for a standard one just for the size and weight benefits- I'd really like a nat luna weekender 50-52ltr as my next one
