My "new" truck. 1987, but runs good and tough as nails. Not as nice as the jeep but needed a bed to carry stuff.
First batch of wood got to the site in good order, as promised. Posts, beam timber,bracing and joists.Treating it now...has about a week to go before we start the real build. I measured moisture with my mid level meter and registered between 13% and 19 %. Have no code for the wood type, but was within 3% on each of the settings. It air dried for a month under a shed in a good breeze and about 75% humidity. My sawmill lady said it got there decently dry for the start.My Maze spiral 14d hardened nails hammer in just fine.I am running some "perc" tests...for lack of a better word..in my septic pit which will get the water after it passes through the two tanks. Shallow, but big in area (6x9)...about 1500 gallons. Three days at 40 gallons a day and at the end of day three...5 hours after the last water dump...all gone. We are about a month out of the rainy season, so this also looks good.As far as the septic...Made in NICA and seems peculier to LA and maybe Europe. I have not seen any info on a system like this in USA. Two tanks and a pit or a drainage field. Tank one holds solids and tank two liquid is sent to bottom and filters through pumice stone. From there goes to pit for absorption back into the earth. Tanks are various sizes. I have 300 gal primary and 200 gal secondary and then 1500 gal pit which is oversized for this. The system is supposed to be good for 4 people and no grey water. Estimate 3-4 year pump out on tank one with that size and load. I know people who have had with two people (and some guests) for five years and no pumping. which is good, because we don't have pump trucks here.
