Water Levels Revisited
Started by frazoo, September 14, 2010, 12:45:59 PM
frazoo
I read here somewhere some time ago about using water levels.  One example used here had the flixible tubing and a bucket.  In talking to an old blocklayer last week, he said they used to use just clear flexible tubing with both ends attached to a short piece of furring strip (from 2 to 3 feet long).  He said you would keep the ends of the tubing capped to keep the water in while not in use stored behind the truck seat and then when you were in place, remove one or both end caps on the tubing to allow the atmospheric pressure to equalize at both ends, giving you a level reading.
I don't know this guy, he might be telling me straight, or pulling my leg.
1.  would this work?
2.  is it as good or better than the bucket method, or same results just different design?
thanks, frazoo
...use a bigger hammer
Yes it works. Easier to see if you use some dye or colorant in the water. Maybe concord grape juice.  :-\
dug
I have not used the bucket method so I am unsure what, if any advantages it may have. I have used the plain old tube method and I can say that it is very accurate and easy, just make sure to wait a minute after you move it to let it settle.
astidham
If your water level clear tubing gets cloudy, you can run 1 cup of vinegar through it a few times! it will clean it up
— Henry Ford
That's a good tip!
Does it help with grape juice stain? Or is clorox best for that?  d*
TheWire
Also,  make sure there are no bubbles in the hose.  That can significantly affect the accuracy of a water level.
frazoo
Thanks Guys!
MD, I guess a nice red wine would have the coloring of the fruit AND the acidic quality of vinegar. ;D  (Of course I would NEVER, EVER think about drinking the leftovers) ::)
frazoo
325ABN
I made one the other week and it works great.
HOWEVER
I went and spent the $200 on a RC laser and its much much much more efficent for one guy working alone.
The water level is dead on accurate. ??? d*
Mrdecatur217
wow now thats a house,. you are doing a great job,. i guess being as smart as natalie payed off
Potassium permanganate makes a nice purple color and will not go off or grow mold, just disolve the crystals and your done, usually available at the chemist
frazoo
Dang, I should have thought of the KmNo4, I use it everyday!  Very pretty color, but heck to get off the skin.  Thanks UK
Made the water level today will be going to site tomorrow to test and use.  Hope to have some progress pics posted soon.
frazoo
