regarding wood or corrugated metal bathroom walls
Started by rusticrural, March 01, 2023, 09:55:36 AM
rusticrural
just had to wonder if theres any particular forum or non-forum advices on completely walling a small bathroom with either wood or corrugated metal? it'll be for indoor uses (with an exhaust fan to suit indeed)
this corrugated example is the kind of compact room size I had in mind
https://i.pinimg.com/originals/35/e3/e5/35e3e54fc865c21da1c37be92fa8df26.jpg
thanks
Don't see why it couldn't be done.  If using wood though, I'd be sure to seal it well and calk as needed.
I used a galvanized corrugated metal walled shower when visiting someone. It seems to have worked well for a number of years. Concrete floor sloped to drain.
rusticrural
thanks to both of you, funny enough I had also been wondering a bit about reasonable ideas for different bottoms and mm I guess I hadn't really thought of a formed concrete slab so that one'll go onto the list too
