Re: posting pics here
Started by jraabe, November 25, 2004, 11:23:48 AM
jraabe
On the edit bar (tag icons) the fourth from the left on the bottom row is a tiny picture frame. Roll the mouse over it for a label - "insert image". You paste the image URL between the tags.
More info: http://countryplans.com/cgi-bin/yabb/YaBB.cgi?board=news;action=display;num=1099677798
I've tried that several times with a picture hosted at tinypic and couldn't  make it work.  Maybe I'm not smart enough to do it????   Example below -there is supposed to be an image per the instructions you gave.  Glenn
jraabe
#2
Glenn:
I can see you tried to post this image with a tag
http://tinypic.com/kycfs
For some reason it works fine when you click on the link above but may be too big to be shown on the page. I just copied in into the message and it became a live link - without using the img tags. (I guess I'm learning here too) ;D
Here is a quick sketch I scanned and they uploaded to tinypic for the url. I copied this smaller image into the space between the img brackets.
You can test your tinypic image by first copying the url into a fresh blank browser page to see if it shows up correctly (images can't be too big).
simon
Just testin to see if I figure out the posting pics...
        Simon
