Finally land is clear!
Started by locomoe, February 11, 2017, 02:18:06 PM
locomoe
Finally got land clear on bluff and trying to get foundation going!
locomoe
also....is photo bucket the only to send or attach pictures on here?? I'm issues getting them to upload?
You can upload them to Google + also and then right click and copy image location then use the picture button above and paste the location between the center brackets.  I have also used Facebook but not sure if they allow over a longer period of time - initially they showed up.  Just about any online hosting site should work if you can get the img location right clicking. :)
troy
Guess I'll stop lurking long enough to help out a bit... check out http://www.imgur.com.  It's hands-down the easiest site for posting images and creating galleries.  It'll even generate the code needed to include images here or any other forum you're on.
There's also an awesome little utility at http://www.bricelam.net/ImageResizer/ that can help make your photos more web-friendly.  With this utility, you can take those ginormous images from your camera and quickly resize them to just a few hundred kilobytes (makes for much faster uploads) and will also reduce the physical size so they work well for forums.
With just a few clicks, you can resize and upload all of your photo updates.
Good luck!
locomoe
azgreg
ChugiakTinkerer
I second that!
Good luck on your adventure and take lots of picture.  Then take some more.  You'll appreciate seeing the progress.
locomoe
yes thanks guys! we're using the Victoria cottage plan with the 14x24 addition as our kids "apartment"....and they're college age!  ;D
