Medeek Project Plugin
Started by Medeek, January 14, 2023, 04:50:14 PM
Medeek
Version 1.1.6 - 02.13.2024
- Added foundations within the Medeek Estimator: Slab-on-Grade, Slab, Stemwall, Grade Beam
There is still a lot more work to be done with adding all of the various hardware and items into the estimating for foundations.  This is just a start.
Nathaniel P. Wilkerson, P.E.
Medeek
Version 1.1.7 - 02.17.2024
- Enabled custom rebar within the Medeek Estimator for Slab-on-Grade foundations
Per customer request.
Medeek
Tutorial 5 - Estimating Custom Rebar (12:15 min.)
Medeek
Version 1.1.8 - 02.21.2024
- Updated custom rebar within the Medeek Estimator to include unit and total length.
- Added custom rebar within the Medeek Estimator for Slab, Stemwall and Grade Beam foundations.
- Updated the Medeek Estimator so that multi-ply (custom) Window and Door headers are properly called out and quantified.
- Added additional logic into the Medeek Estimator so that assemblies are ordered in the report logically by their assembly names.
Medeek
#29
Version 1.1.9 - 03.22.2024
- Added a Weight Database to the Medeek Estimating Module.
- Enabled Weight Analysis to the Medeek Estimating Module for Rectangular Wall Panels.
- Fixed some minor bugs with the estimating module for wall panels.
Medeek
Version 1.2.0 - 03.23.2024
- Added Headers (window, door, garage) for walls within the Medeek Estimating Module.
- Added Blocking for walls within the Medeek Estimating Module.
Medeek
Version 1.2.1 - 03.27.2024
- Added cost analysis for windows units in walls within the Medeek Estimating Module.
- Added additional logic into the Medeek Scene Generator so that assemblies are ordered in the report logically by their assembly names.
Medeek
Medeek Project Plugin **Tutorial 6** - Estimating Weights and Costs (13:52)
https://youtu.be/vWXrEG_FWgc
Medeek
Version 1.2.2 - 04.20.2024
