Eighty acres in the Okanogan
Started by Karl, June 30, 2011, 07:22:35 PM
Should be a top plate on those walls though  ???  Bottom plate, stud, top plate and 2nd top plate installed after walls are stood up and nailed together.
Otherwise, looks great!  I don't use plywood sheeting so can't answer that question I guess. I use OSB and stand it vertical but with 10' walls I go 8' up from the bottom of the rim joist/floor joist to as high as it will reach then add another piece to get all the way up and make sure it goes to the 2nd top plate to tie it all together.
Karl
#26
yeah, that pic is before the second plate went on
There's another shot where you can see it above the door opening if you squint right.
