Drywall adhesive, use or no ?
Started by Arky217, May 24, 2011, 09:24:55 PM
Arky217
Is it a good idea to use drywall adhesive on the ceiling drywall ?
On the wall drywall ?
I am trying to decide if I should go to the trouble of using drywall adhesive. It appears not to be used much around this area, if at all (Western Arkansas). The hardware and box stores don't even seem to carry it.
I was thinking about using it on my ceiling and exterior walls because they are constructed from rough cut lumber and the surface, or course, is not going to be nearly as even as if I had used milled lumber.
Someone told me to just use a few extra screws than typical and don't worry about it. But I was wondering if it greatly added to the strength of the attachment.
Under what conditions is it advisable to use drywall adhesive, and when is it pretty much just a waste of time and money ?
Arky
fishing_guy
When I used to hang drywall...mind you is was 30 years ago, we screwed for one boss who didn't like the added expense, and glued and screwed for the other who wanted NO callbacks for nail pops.
Either way will work and is correct, it is more a matter of how much you want to spend to never get a nail pop.
