Frame the house
Started by kellygreer, April 23, 2024, 02:52:18 AM
kellygreer
Hello,
I'm trying to frame a house alone :). I wonder if it could be done in 10 foot sections and then tied together with the top plate.
rothbard
The options I was looking at
(1) Framing first, then sheathing, to keep weight down
(2) Get some scaffolding, then do the old school balloon framing method of toenailing a couple studs up, then the top plate, then fill in the studs using the scaffolding
(3) Follow what cody did ( https://www.countryplans.com/cody.html ) and do it in panels.
(4) Do it in sections and use the interlocking top plates
Only option (3) makes me particularly nervous, but Cody pulled it off well.  If you decide to not have to raise a wall at all, essential craftsman has a video of (2) https://youtu.be/d7pDvk8r3jI?t=608
arieeed
Quote from: kellygreer on April 23, 2024, 02:52:18 AMHello,
Framing walls on the ground and then raising them requires additional tools and equipment like a crane or scaffolding.  Building the walls upright in place is much faster and requires less manpower.
Here are some resources that can help you with house framing:
