Author Topic: Truss Calculators  (Read 363449 times)
Offline Medeek
  • Structural Engineering
Re: Truss Calculators
« Reply #975 on: April 12, 2020, 03:22:02 PM »
Version 2.7.0 - 04.12.2020
- Enabled the "Edit Truss Assembly" function for all timber trusses (imperial and metric units).
Nathaniel P. Wilkerson, P.E.
Offline Medeek
« Reply #976 on: April 13, 2020, 08:19:25 AM »
Version 2.7.1 - 04.13.2020
- Enabled the "Edit Roof Assembly" function for shed w/ ledger rafter roofs (imperial and metric units).
- Enabled soffit and fascia for shed w/ ledger rafter roofs: boxed, gable, angled.
- Enabled a roof cladding extension parameter for shed w/ ledger rafter roofs.
- Added the option in the shed w/ ledger rafter roof edit menu to specify a separate front and back overhang length.
- Enabled a "No Framing" mode for shed w/ ledger rafter roofs.
Offline Medeek
« Reply #977 on: April 20, 2020, 08:54:48 PM »
Velux has their official models in the warehouse but as usual there are too many details in these models, so I had to create my own low poly versions that are dimensionally accurate:
https://3dwarehouse.sketchup.com/model/f56a0a28-e161-46ce-a051-ea081c9e2a74/Medeek-Skylights-Velux-Low-Poly
Offline Medeek
« Reply #978 on: April 21, 2020, 09:22:23 PM »
First look at the Skylights Toolbar:
Offline Medeek
« Reply #979 on: April 23, 2020, 10:42:40 PM »
Version 2.7.2 - 04.24.2020
- Added wall sheathing thickness and wall cladding thickness parameters to the advanced options for trusses.
- Enabled advanced options for tail bearing trusses.
I still need to enable editing and labels for tail bearing trusses.
Offline Medeek
« Reply #980 on: April 24, 2020, 02:53:56 PM »
Version 2.7.2b - 04.24.2020
- Enabled the "Edit Truss Assembly" function for all tail bearing trusses (imperial and metric units).
- Labels and callouts added to tail bearing trusses.
This update also resolves a potential bug that could cause the plugin to go into a infinite loop if the birdsmouth cut exceeds the depth of the top chord of the truss.  If you are using tail bearing trusses I highly recommend upgrading to this latest release.
The updated module is now properly creating the gypsum on the underside of the truss (three pieces).
Offline Medeek
« Reply #981 on: April 26, 2020, 04:51:48 PM »
Version 2.7.3 - 04.26.2020
- Added a Global Reset button in the General tab of the Global Settings.
Offline Medeek
« Reply #982 on: May 02, 2020, 07:51:51 PM »
Version 2.7.4 - 05.02.2020
- Fixed a bug with the soffit and fascia module for all truss types.
This bug fix is specifically for the boxed soffit for truss roofs.  Previously if one did not enable the fascia but enabled the soffit then it would throw an error.  There may be other similar bugs in this module or others so I am constantly testing combinations of various parameters to make sure no interdependencies have been overlooked.
Offline Medeek
« Reply #983 on: May 05, 2020, 08:40:58 PM »
Version 2.7.5 - 05.05.2020
- Enabled a toggle feature (Ctrl key) for the Trim tool so that the selection can be retained or removed.
This small adjustment of the Trim tool is to bring it inline with the Trim 2 tool. This feature is per customer request.
Offline Medeek
« Reply #984 on: May 09, 2020, 11:03:06 PM »
First look at the skylight tool in action:
Note, that this image shows the skylights added to a generic roof.  For the cutouts to work the roof geometry must be a valid solid group or component within an overall assembly group for the roof or building.
Initially there are three skylights (sizes) to choose from however it is possible to add your own skylights into the library.
The cut function can be toggled on/off in order to cut through the sheathing and cladding or in this case just a generic roof solid.
At some point I would also like to add in a few VELUX Sun Tunnels.
Now I just need to figure out how to heal the roof when a skylight is deleted or edited.  For a Medeek roof that is fairly straight forward, just regen the roof, however for a generic solid things get a little more tricky.
Offline Medeek
« Reply #985 on: May 10, 2020, 11:19:30 PM »
Version 2.7.6 - 05.11.2020
- Added the Skylights toolbar.
- Enabled skylights for all truss, rafter and complex roofs.
- Enabled skylights for generic roofs.
I also added an additional tool for "regenerating" the skylights, this comes in handy after modifying the location of a skylight or if a Medeek roof gets regenerated and the holes in the sheathing and cladding need to be re-cut.
There are few new global settings I still need to add to fully complete this new module but overall it seems to be working quite nicely.
Offline Medeek
« Reply #986 on: May 21, 2020, 11:48:46 PM »
Tutorial 18: Skylights (14.22 min.)
https://youtu.be/ogWO8nQRaxU
I often get a lot of questions that are answered in the tutorial videos.  Just a reminder, all of the tutorial videos can be found here:
http://design.medeek.com/resources/medeektrussplugin.html#Videos
Offline Medeek
« Reply #987 on: July 31, 2020, 05:16:23 PM »
Version 2.7.7 - 07.31.2020
- Fixed a bug with all assemblies when auto-assignment of materials is turned off in the global settings.
Offline Medeek
« Reply #988 on: August 16, 2020, 08:24:19 PM »
I've been giving some serious thought to the estimating module the last couple of days as I regroup and review my various todo lists.
I would like to spend a few days and update the estimating module to include rafter roofs.  However, as I think about rafters and their lengths I am wondering what length exactly are we talking about?  Do we want the actual (longest length of the member) or do we want a horizontal projection of the length?  Typically both the top and bottom of a rafter has a bevel cut or even a compound bevel cut.
The ridge board on the other hand is very simple (generally).  There are no beveled end cuts so things are straight forward.
« Last Edit: August 16, 2020, 09:22:15 PM by Medeek »
Offline Medeek
« Reply #989 on: September 12, 2020, 02:53:48 PM »
In a nutshell this is the basic algorithm for the rafter module for complex roofs:
Of course the devil is the details and there are a lot of details missing in this picture.
The overall picture seems simple enough however there are a number of special cases where rafters align with ridge boards and the over simplistic boolean subtraction algorithm will not suffice.  I will need to try and account for all of those special cases.
The offset is a factor of the ridgeboard, hip rafter, valley rafter or flying hip rafter width.  However, as you can see in the detail below when the roof planes are not the same (asymmetric) the offset will not be symmetric and must be calculated, hence the opposing roof plane (pitch) at that edge must be known/tracked.  For a ridge board edge the offset will be given by:
offset  = T/(1 + tanθ/tanA)
Since the offset is only a function of the ratio of the two opposing pitches this equation should also hold for hips and valleys as well.  Note that when the angles are equal the equation degenerates to T/2 as one would expect.
Once all of the offsets are determined then it is merely a matter of generating the new points for the polygon drawn in blue highlighter.  Once that polygon (points) is determined it becomes the cutting polygon for the rafters.  Technically it is a boolean intersection rather than a subtraction, but that is all semantics.
Offline Medeek
« Reply #990 on: October 09, 2020, 02:48:55 AM »
Version 2.7.8 - 10.09.2020
- Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
Offline Medeek
« Reply #991 on: October 23, 2020, 09:18:20 AM »
Version 2.7.9 - 10.23.2020
- Fixed a "rounding error" bug for pyramid shaped hip rafter roofs.
Offline Medeek
« Reply #992 on: December 08, 2020, 07:48:44 PM »
Tutorial 19: Polygon Floor Workaround (21.46 min.)
https://youtu.be/G9Hrq1PzIUE
Manual workaround until the upcoming Medeek Floor plugin is released.
Offline Medeek
« Reply #993 on: February 10, 2021, 01:41:36 PM »
Version 2.8.0 - 02.10.2020
- Minor modification to the range of available pitches for valley truss sets.
Offline Medeek
« Reply #994 on: March 13, 2021, 08:43:20 PM »
Version 2.8.1 - 03.13.2021
- Standardized the naming convention of the plugin toolbars.
All of the Truss plugin toolbars will be prefixed with "Medeek", this will make it easier to find and sort through them, especially if you have a large number of extensions installed.
Offline Medeek
« Reply #995 on: March 24, 2021, 01:29:16 PM »
Version 2.8.2 - 03.24.2021
- Added additional pitches to the shed and shed w/ ledger draw menus.
Offline Medeek
« Reply #996 on: June 04, 2021, 08:40:26 PM »
Version 2.8.3 - 06.04.2021
- Added four additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus and buttons.
This completes the user interface upgrade for all the major Medeek plugins.  The Truss, Foundation and Electrical plugins are now up to par with the Wall plugin.  Now on to bigger and better things, that task was very tedious but necessary.
Offline Medeek
« Reply #997 on: June 13, 2021, 05:02:11 PM »
Version 2.8.4 - 06.13.2021
- Added a "Regen" context menu item for all truss assemblies (eg. Common Trusses, Scissor Trusses, Timber Trusses etc...)
- Added an option for subtractive geometry into the General tab of the Global Settings.
- Sub-groups within truss assemblies can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
- Components within truss assemblies can also be made persistent and "subtractive" by naming the component instance to (subtract1, subtract2, subtract3, etc...)
Once I've tested this a bit a further and received more feedback I will enable the same subtractive option/feature for rafter roofs and complex roofs.
Offline Medeek
« Reply #998 on: June 13, 2021, 08:28:00 PM »
Version 2.8.4b - 06.13.2021
- Subtractive geometry can be constrained to only subtract from Sheathing and Cladding by setting the subtractive geometry parameter to "SHEATHING" in the global settings.
... and this is why feedback is important.
Offline Medeek
« Reply #999 on: June 14, 2021, 05:58:22 PM »
Version 2.8.5 - 06.14.2021
- Added stats (roof cladding) for common and monopitch truss roofs which can be analyzed within the Medeek Estimator (Wall Extension) module.
- Enabled net area calculations for roof sheathing and roof cladding statistics.
If cladding and/or sheathing is removed by subtractive geometry or features such as skylights, this information/data will be recorded and accounted for within the assembly.  When the Medeek Estimator runs it will pick up the net and gross areas for cladding and sheathing and report the correct amounts.  Previously only the gross areas were reported by the estimator.
« Last Edit: June 14, 2021, 06:13:37 PM by Medeek »
Style sheets: 0: .
Files included: 32 - 867KB. (show)
Cache hits: 11: 0.00144s for 40,850 bytes (show)
Queries used: 29.
