Mini Split Heat and Cool
Started by Billisnice, October 16, 2009, 08:29:03 AM
Billisnice
Would mine split hvac units be ok for 16 x 24 with loft?
I cant see why a unit sized correctly would not work. Do you need heating or cooling mostly. From what I recall heating is not their strong point at low outside temperatures.
"the heating capacity drops dramatically at low outdoor temperatures, moving approximately 40% of the heating capacity at 10 degrees."
Insulate and air seal the structure well.
