Half a flying H
Started by peternap, March 09, 2009, 08:07:49 PM
I've been meaning to post this for a while.
For those of you that need to crosscut large beams or poles an need precision, here is the half flying H. It acts like the shoe on a Skilsaw and allows you to cut on the line with a good deal of control. A full flying H has the angle iron on both sides but I found I couldn't see the cut as well.
One more dedicated saw ???
Peter I had enough trouble with the Alaskan  Sawmill.  Chainsaws, metal and me are usually not compatable. ;D
Did you have to use two bolts to keep it from pivoting?
Quote from: Redoverfarm on March 09, 2009, 08:53:25 PM
Yep...two bolts and a washer on each one to space it from the chain..
Ernest T. Bass
That looks handy! Drilling through a bar is really tough if you don't have a serious press, though.. We made a jig for squaring logs and it took at least a half hour to make those holes..
diyfrank
I have a few old bars, I may give that a whirl. [chainsaw]
Home is where you make it
