Cabin project in east washington
Started by diyfrank, November 22, 2008, 11:25:11 PM
diyfrank
Heres an update to my progress, I'm getting there slowly.
I have my stairs built and a start on my siding.
Home is where you make it
Cool!  It feels good to make progress doesn't it?  [cool]
astidham
— Henry Ford
diyfrank
I haven't updated in a while and yes It feels good to be making progress no matter how slowly it may seem.
I have the rest of the siding done and finished the Hardie singles.
The weather is trying to turn on me but I feel good about getting this far.
diyfrank
 My ridge cap when purchased came with a roll of either a roll of a solid foam to seal the ridge cap down or a roll of a lighter type that is breathable for a vented cap. Mine is vented so I have the breathable foam.
Question, Would sealing up the roof panels with a spray foam like Great stuff be good or bad and still allow the inside of my roof to continue to vent. ???
I see you used a ladder leaning against the roof to work on the ridge cap...how'd that work out?  I have a 28 foot ladder that I might have to try this with but the ridge cap at the tall end of mine is 19 feet up!
diyfrank
I haven't been up there to work on the cap yet but I did give it a test climb and it feels right. I just position the ladders for the next trip.
I'm right at the 19' mark also.
Quote from: diyfrank on October 25, 2011, 06:23:29 AM
How long is the ladder?  I'll have to try that and see how it works.  My son can hold the bottom I guess though maybe some big spikes would be good too!  Just seems like an awfully shallow angle?
I need to get my ridge cap properly buttoned down and the gables done but I've neglected to get it done all summer and here we are coming into winter again :(
diyfrank
My ladders are 24' and feel very solid. If you adjust the angle to match the pitch it has a feeling like it belongs there.
I've seen guys at work take a heavy piece of plywood about 1' square and nail a small box onto it from 2"x2" making a box the ladder feet set into. A couple hole in the plywood allow spiking it to the ground.
Quote from: diyfrank on October 25, 2011, 09:26:58 PM
Cool thanks!  Then my 28' ladder should do the trick and maybe I can finally get the ridge cap done!  I ned to affix it completely and box the ends in as well as get the gable trim on....time to give this a try!
