Anyone using micro hydro power?
Started by BiggKidd, April 14, 2008, 09:23:19 PM
Good points, Don.  A lot of the success/failure of this project can be determined by numbers-- With head and available flow info you can calculate the possible available power.
Here is a simple weir that can be made from plywood to calculate gallons flow per minute.  I used one when drilling wells to estimate water flow.
http://www.lmnoeng.com/Weirs/vweir.htm
BiggKidd
Glenn, Don,
  First I understand about needing ACCURATE flow #s. I can only estimate until I can get out there With some decent tools and spend some time watching / testing. I know from what I have seen recently that we are also going to have to watch out and build with storm flow in mind. I learn a little more each time we go up. I have tried using my Garmin GPS to get elevations but for some reason it just isn't working right there. Works fine here and everywhere I have tried it. Almost like a giant Iron plate is under our property. So I have to do it the old way & clear lines of sight and use a transit to get the #s. I'm sorry to say I just haven't had the time. Going off the cuff with a life time of working evevations I would estimate at least 50 feet of rise and a flow during normal times of at least 5 gal. a min. A lot more I expect but I have not been able to test it yet. I don't have any experiance with water flow or flow rates so I can't make an educated guess about this. This was one of the primary reasons I built the dam. I needed it for water storage also but once I can measure the flow coming over the top I will know a lot more.
Dont forget I also have a Big creek no head to speak of but huge amounts of water. So I realy have two chances at this. A high head low flow and a low head high flow.
I do appreciate being able to bounce my silly ideas around with you guys. When I talk with the people I know most of them just look confused. Don't get me wrong they are not dumb, just don't have any idea about this type thing. Thats not saying I know any more. :)
Larry
Larry
Hmmm.
Entering 50 ft head and 5 gpm flow into that calculator at
http://www.nooutage.com/hydroele.htm
comes up with a potential 18 watts power output. Unless that was generated right beside the point of use (the electrical use) it wouldn't do you much good.
Larry, I think with the low head situation at least on the big creek, you would be better off to go with a water wheel.
Efficiency won't matter so much if you have enough brute force.
http://ipc6.permaculturewest.org/ch08/shannon/index.html
If you do one of these don't forget safety screens etc, to prevent animals and children from running through them and ending the fun.
BiggKidd
Don, Glenn,
Thanks for the input and links. I was planning to work on it this weekend but it looks like other things are going to grab my time. I would like to atleast fix the dam but there is only so much time.
Larry
Larry
Larry,
I have to guess that you have more than 5gpm flow, as that is pretty wimpy.  That is about the equivalent of a garden hose output at roughly 23psi.
Build your dam / diverter into a small pipe and measure the flow.....
18W could be easily had with a fairly cheap solar panel.  I bought a 53W panel a few years ago for $275.
-f-
Useful info from Backwoods Solar - Using DC and AC
I went the AC 2 inverters on all the time route -- others may want to use less.
http://www.backwoodssolar.com/newsletter/articles.htm
BiggKidd
Hey Glenn
Thanks for the links its been a while since I have been over to backwoods. Bunch of good info.
Larry
Larry
I need to keep refreshing too - brain leaks.
I find useful info there at backwoods, and a few products I haven't seen before, BUT they pretty much always seem to charge more than the place across the river from me.
They are a good place of reference but a little too steep for me.  I then go looking for the dealers and price breaks on their products.
I don't think I ever bought from them - I nearly always shop.
My favorite is still Affordable Solar but I also have a good look around as well.
