Toilets, Part Two
Started by MountainDon, March 16, 2008, 07:44:16 PM
If you have a camp/cabin/farm as a second home what type of toilet do you use?
1.6 GPF
Dual flush rates
Older 3.5 GPF (82-93)
Older 5-7 Gal Mega Flush
Older, with brick(s)
Chemical
Composting, commercial
Composting, DIY
One Hole
Two Hole
Those bushes over there
Other (please add details in message)
Part Two, inspired by someone who's brain was working faster than mine. Thanks -f-
We're chemical for now. SunMar composting in the future.
EDIT see http://countryplans.com/smf/index.php?topic=4208.0 for "part one"
More variety out in the woods than at home   ;)
hnash53
Don, I have an RV toilet installed inside my cabin, plumbed for water just like in an RV.  I have two 10 gal totes that I connect to the pipe directly under the toilet underneath my cabin.  RV  toilets use little water, and so the totes last us awhile.  When full I just load the totes in my vehicle and take and dump at an RV dump station.  Pretty simple system to operate and maintain.  In fact, my cabin operates much like a permanently parked RV.  I have an RV propane hot water heater, 12 volt water pump, along with the RV toilet.  We haul our water in and pump it into a plastic 55 gal barrel.
When we are out at the cabin, I usually find a tree to water, and encourage any other men to water the surrounding aspens and firs.  Cuts down on cabin water use and adds much-needed nitrogen to the earth.  And as for the ladies flushing the toilet, my daughter says (always in her own way), "Hey Dad, if it's yellow, it's mellow; if it's brown, it's down."
Amazing just how little water one can do with if only a little effort and attitude change is made.
Good to see you around here Hal.
How is your solar  electric system working? Did you get the wind working for you?
Don
Toilets - Part Two...Did you mean Number Two, Don?  hmm
fyremare
Our "other" is a potty chair that we found at a yard sale. So we're a modified one holer at camp! We dig a hole, put the pot chair over it and when the hole needs to buried.... time to move the pot chair! ;D
Cool.  That's how our original started out -- 2' high plywood sides with a one holer and no walls to spoil the view.  We used lime dipped out of a bag with a paper cup to cover  our creations.  It keeps the rodents from lunching out and fossilizes them for future geologists to find and learn about our civilization.
Welcome to the forum.
No Glenn.  n*
...as in, here's Part One of this survey, and what you bare reading is Part Two.
I should've known better.  ::)   Should've named 'em Part A, Part B.....
hnash53
Don, I've not made the commitment yet to live out there full time...still trying to build it all in my head before I actually launch.
StinkerBell
a childish response......
Sure glad you said "Re: Toilets , Part Two
instead of             "Re: Toilet's Number Two
;D
Quote from: MountainDon on March 23, 2008, 10:45:50 AM
No Glenn.  n*
Don, What happens when you add Part A to Part B?   Any danger? hmm
Quote from: glenn kangiser on April 02, 2008, 12:27:14 AM
No Glenn.  n*
Maybe this ,
Peg I'm not goin there  :P  but pretty cool for those who have to share everything  ::)
Together through thick and thin...
