An agreeement!
Started by StinkerBell, August 01, 2007, 10:42:05 AM
StinkerBell
 ;D
Hubby and I finally came to an agreement on a house plan. It is my version of a farm house. Although it is not one from here (I have purchased a couple) I have no regrets of my purchase. I learned a great deal!
We are going with a 24 X40. As soon as I get it down on a computer program I will post it here for all to see. Plus any pointers would be good!
edit...I think this might be in the wrong forum, yet again! Please move if needed. Thanks
This forum is OK Stink.  You can continue here with your project if you wish.
I would suggest that Hog sign the agreement with "UCC 1-207 Without Prejudice" before his signature,  on this agreement in case he needs to fall back on his Constitutional Rights. ;D
Just giving you a bad time. :-/
Whatever you decide is fine with us.  You are part of the group and we are here to serve. :)
NetHog
I need to send off for another copy of building code information sent by Stevens county... seems last one got thrown out.
;D
Anyone remember how steep staircase can be in Washington?
Now Hog, quarters are a bit cramped and something has to be done with some of this clutter. :-/ :)
Haven't found it yet but John posted some info on stairs.
Here's a tutorial for 3DHA on stairs with some good info -- but not what I was thinking of yet.
http://www.countryplans.com/3dha/Levels/Stairs/Stairs.htm
Try this.
http://www.stairways.org/pdf/2003%20Stair%20IRC%20SCREEN.pdf
and John's notes on another thread.
Quote
YaBB Administrator
Whidbey Island, WA
Re: review floorplan
Reply #10 - Jun 5th, 2007, 8:58am
Stair Notes (UBC) (this is my normal stair spec.)
- Max rise of 8", Min. run of 9", Max variation 3/8"
- Min. width 36" clear
- Min. headroom 6'- 8" above slope of treads
- Framing from 3 2x12 stringers notched over 2x6 cleats top & bottom (alt metal brackets)
- Treads 5/4 composite hardboard or equal, risers 3/4 stock.
- Storage under stair protected with 5/8" type X GWB taped airtight.
- Handrails needed for stairs of 4 or more risers.
- Handrails to be 1-1/2" dia. 36" above nosing w/ return to newl post or wall.
- Stair sidewalls to be Min. 36" high w/ 1x6 cap, GWB @ exposed sides.
- Stairs (code) not needed for under 200sf lofts. Btwn 200 to 400 spiral stair can be used.
New IRC 2003 code stairs (differences):
- Max rise of 7- 3/4", Min run 10",
- Winders min 6" at inside corner and 10" at walk line 12" inward.
Back to top
NetHog
I may have some additional tweeks to the steps then  :-/
NetHog
Stink's drawing up a new plan...
This should be interesting... :)
StinkerBell
#9
I decided I am to much of a chicken to build something two story's high. I am able to get up on my one level roof, but the second level roof at my current home is too high. Gotta go with a ground level and a basement.
ok where is the chicken emote?
Just takes a bit of getting used to, Stink. :)
StinkerBell
As soon as we get the Law of Gravity repealed, then and only then will i get up on a second story roof.
deertracks
When we checked, Stevens County had just implemented a new soil test
that had to be done for basements. Maybe it's no big deal, but
check with them just in case. We've found them easy to work with,
but we only have a crawl space.
StinkerBell
It is a soil test for Radon. Or I should say a test to see the level.
deertracks
Hope it all goes smooth for you.
Another test to have to pay for!!!
That looks like a large house. How many sq. feet?
StinkerBell
36 x 36
With a full basement.
QuoteIt is a soil test for Radon. Or I should say a test to see the level.
Why are they worried about your radon when they have Hanford? :-?
Quote56 million gallons of radioactive waste stored in 177 underground tanks, sixty-eight of which leak. 2,300 tons of spent nuclear fuel sitting in (and sometimes leaking from) two pools only a few hundred feet from the Columbia River. 120 square miles of contaminated ground water. 25 tons of plutonium that must be disposed of and kept under constant armed guard.
And, that is what remains at Hanford after over 7 years of the most intensive environmental cleanup project in history. How did this happen?
Just wondrin'
http://usgovinfo.about.com/library/weekly/aa102497.htm
StinkerBell
#17
Glenn you are a wet towel. :P
Sorry Stink, I just wanted to make you feel like your little problem wasn't so bad. ::)
...and highlight the hypocrisy of the ruling class. ;D
StinkerBell
JURY DUTY IN LESS THEN 12 HOURS........... >:(
I decided to pick my nose, I am going to spend the whole day just picking it. I hope everyone see's me.
That's real nice, Stink.  I hope the chairs have cloth upholstered armrests for your sake. :)
...don't forget to post pix.
I did my civic duty today.  Went to the County Supervisors meeting to put in a good word for our Historic Cinema and non-profit educational theater.
Some local right wingers decided it would be cool to use dirty politics to try to shut it down.  It would have destroyed 11 years of a good man and associates work plus likely destroyed the restoration of a hundred year plus old building.  Government and politics suck. >:(
We prevailed BTW.
They used the building inspector to change occupancy, dirty reporting in the  local dirty rag newspaper and whatever they could to try to destroy it.  I'm PWP.
