Help me building cottage.
Started by dhuppi, September 30, 2006, 04:59:43 AM
dhuppi
I am located in india. I have a small pice of land in one of the hill stations in india. Now I would like to construct a new cottage. Can anyone help me with this. i have a land measuring 1500 X  2000 feet. I would like to construct a house with an atick. It should have four rooms, one kitchen with dining, room,one bathroom,sitting room, small study. I do not know how to go forward with designing. master and guest room should have attached bathroom.
Thank you.
Hello, dhuppi.  Welcome to the forum.  It is probably easiest to take a set of plans such as the ones John has and modify them to fit your needs.  His plans are very reasonably priced and will give you a safe structure that is easy to build.
Since you want rooms added to the main rooms and an attic the Big Enchilada Plans might be a good choice.  The plans tell you everything you need to know about building your cottage and we are here to help with questions.  John also has a special support section for people who purchase plans from him.
Even if you don't use his plans, this forum is open to you for help.
Here are all the plans     http://www.countryplans.com/plans.html
Here is the Enchilada      http://www.jshow.com/y2k/listings/43.html
Do you have access to lumber and supplies for this style cottage?  It is my understanding that wood is in short supply in some areas of India.
Earthbag or, if you're in a grain-growing area, straw bale???  Too many to think about links for straw bale.
There's been at least one earthbag structure permitted in a public building--I think--in a highly seismic area of California.  Although part of that was because it was dome-shaped.
(see Cal-Earth's site for that story--although for a lot of things I like OK OK OK productions a bit better.)
http://www.calearth.org/
http://www.okokok.org/
I was dubious this afternoon when I saw a sign "lot for sale 500 ft by 500 ft.  Five acres."
It is true--in fact it's closer to six.
try it:
http://www.calculateme.com/Area/SquareFeet/ToAcres.htm
So in terms of lot sizes (not farm sizes!!) Dhuppi has a fair amount of land.
JCL
Hi dhuppi,
I am also located at the south of equator, and would like to recommend that you first collect information about your land.
How is the climate? (temperature, humidity, precipitation, wind direction)
Sun exposure and orientation?
Is it similar to a US climate zone?
Does the land has some special characteristic?
(view, inclination, access, vegetation)
What resources and materials are available?
(wood, stones, pre-used material)
What are the builder skills?
Specially in a developing country it is a good idea to start with a lot of information, so you optimize your efforts and avoid costly mistakes down the road.
I employed the sunkit to get some of the info above and also recommend it.
Best wishes, from Brazil,
J Carlos
