14x28 Footings
Started by cre90602, May 20, 2006, 05:35:55 PM
cre90602
I just ordered the plans for the little house kit. I want to put on a regular concrete peir foundation, I have tried getting ahold of John but to no luck. I have acess to a machine to dig this weekend and monday, does anyone know the layout for the footings
I sent you the information on a Private message and e-mail.  Check the top of the page for the link to your messages.
Glenn
cre90602
My pleasure.  Last night was the first night I've been home to get to my plans in a week.  You lucked out. :)
Out selling my body for money again.  Somebody spank me, please. :)
Billy Bob
No wonder you're building RV shelters from free materials! [smiley=2vrolijk_08.gif]
Bill
I'm afraid you caught me, Billy Bob :-/
cre90602
D*** Ididnt have to dig that hole 15 feet wide
I sent a message as well, but we didn't know which plan you were building. (The Little House has 3 sizes)
Thanks Glenn for helping on this. (The plan per Little House) is for 14x24 but you can add an additional bay to the length, just make sure you add an additional pier and that the span on the beam is no longer than shown on the plan. If you are doing drilled concrete piers you can go to a deeper beam spaced further apart (say 6x12 @ 8' o/c) This should be checked with your snow load.
It's generally not a good idea to get ahead of yourself as you will often want to modify something before you go ahead and start the foundation. All the changes above have to be carried by the foundation and each foundation is site specific to some extent.
cre90602
we have rocky sand clay mix soil i had acess to a small tractor backhoe i du a 15x36 hole about 3 ft deep Found some solid earth dig that test you descrided and it did  better then 2500 psi put about 12 inches of clean stone down the line for the footings about 2ft wide going to pour 16" footings and put 8"block and fill them with concrete every 5 ft and g0 with a 2x12 for the beam. I send some pics
Sounds like your rolling. We all love photos!  :)
cre90602
Piers are all poured block going up tomorrow.I cant seem to get photos to post any body have any ideas
Scroll down to the bottom of this tutorial. Only about 3 paragraphs. Should get it working for you.
Yesterday we poured a  a few deck footing . The mud we got was on the tail end of someone else's pour , the mud had been dumped into the pump truck then spit back into the mixer , then sent to our job site . I had added a 1/4  yrd cuz I guessed / figured the other guys might be close figurer in and we'd be short , they where but we weren't  ;)
 Short load fees eat ya up thats why a 1 3/4 yrd pour is a back ender.
Long storey was the mud was almost water , I had the crew screw the brackets to a straight 2x6 that was longer than the lay out of the pier  pads screwed on 44 1/2 " OC ,  go figure  :-/  Butter milk suckin architect :o  ::)Not your plan John so no offence Eh ;)
Any way the 2x6 with the perfectly spaced bracket was staked on the high end and leveled to the other end ,  wallla perfect spaced , in line pier brackets  :)
Quick,  easy,  cool  8-) All because of a small problem , MTL that system will be used in the future when grade  allows :)
 PS Sorry no photos , it was late , and I had to run to another job site .
cre90602
cre90602
[IMG]https://i77.photobucket.com/albums/j54/csilvay/footings021.jpg[/IMG] There we go Ithink I figured it out We set the sonic tube ton level pads and used them to get a level set
HER
Will water collect in the excavation or ar you going to have a drain of some sort?  Looks good.
cre90602
Going to put more stone in hole and drain tile and backfill Then top foo with sone Round stone and landscape fabric
That looks like a serious foundation to me!  :D (Good work!  ;))
You are in a bit of a hollow so drainage needs to be insured (unless the soil will do this for you).
cre90602
Got the blocks on and built the beams
Things are progressing - great.
