Medeek Project Plugin
Started by Medeek, January 14, 2023, 04:50:14 PM
Medeek
Version 1.1.6 - 02.13.2024
- Added foundations within the Medeek Estimator: Slab-on-Grade, Slab, Stemwall, Grade Beam
There is still a lot more work to be done with adding all of the various hardware and items into the estimating for foundations.  This is just a start.
Nathaniel P. Wilkerson, P.E.
Medeek
Version 1.1.7 - 02.17.2024
- Enabled custom rebar within the Medeek Estimator for Slab-on-Grade foundations
Per customer request.
Medeek
Tutorial 5 - Estimating Custom Rebar (12:15 min.)
Medeek
Version 1.1.8 - 02.21.2024
- Updated custom rebar within the Medeek Estimator to include unit and total length.
- Added custom rebar within the Medeek Estimator for Slab, Stemwall and Grade Beam foundations.
- Updated the Medeek Estimator so that multi-ply (custom) Window and Door headers are properly called out and quantified.
- Added additional logic into the Medeek Estimator so that assemblies are ordered in the report logically by their assembly names.
Medeek
#29
Version 1.1.9 - 03.22.2024
- Added a Weight Database to the Medeek Estimating Module.
- Enabled Weight Analysis to the Medeek Estimating Module for Rectangular Wall Panels.
- Fixed some minor bugs with the estimating module for wall panels.
Medeek
Version 1.2.0 - 03.23.2024
- Added Headers (window, door, garage) for walls within the Medeek Estimating Module.
- Added Blocking for walls within the Medeek Estimating Module.
Medeek
Version 1.2.1 - 03.27.2024
- Added cost analysis for windows units in walls within the Medeek Estimating Module.
- Added additional logic into the Medeek Scene Generator so that assemblies are ordered in the report logically by their assembly names.
Medeek
Medeek Project Plugin **Tutorial 6** - Estimating Weights and Costs (13:52)
https://youtu.be/vWXrEG_FWgc
Medeek
Version 1.2.2 - 04.20.2024
Medeek
Version 1.2.3 - 05.14.2024 thru 05.15.2024
- Fixed a minor bug with the estimating module (wall header library initialization).
- Fixed a minor bug with the estimating module (wall material library initialization).
Medeek
Version 1.2.4 - 08.04.2024
- Added a duplicate title block assembly check to the regen module for all title blocks.
- Enabled wall sheathing 2 within the Medeek Estimating Module for wall assemblies.
Medeek Engineering
The first attempt was a bit crude in my opinion.  After some fiddling with fonts and dimensions things look a bit more presentable:
Medeek Engineering
I'm trying to get it to slow down so you can see the step by step build process.
Medeek Engineering
Tutorial 7 - Garage Builder (16:14 min.)
Medeek Engineering
From the get go the Garage Builder was a proof of concept, and it does seem to work reasonably well.  However, I'm now contemplating creating a slightly more complicated version of this tool called the House Builder.  I will probably initially not include the roof or foundations for the first iteration and primarily focus on the wall layout engine (that is what is most important).
Thoughts?  Is there any interest for such a tool?
In some way it may resemble what Chief Architect does, you create your layout in 2D, fully dimensioned and then like the Garage Builder it can with the push of a button translate that into a full 3D model on demand.
The current algorithms that produce the DXF or printed drawing (PDF) will need to be further developed and augmented so that we can auto-dimension a much more complex floor plan, this should become very interesting.
The goal is to be able to create, at a minimum, something like this in the House Builder tool:
I've also been giving the auto-dimensioning some serious thought and even as attractive as this may seem, there will always be cases where the user will need to manually intervene and add or subtract dimensions.  So I will need to build some sort of user driven dimensioning system that will allow manual override but somehow coexist with a fully automated dimensioning system.
In addition to dimensions we will also need to enable some sort of annotation system with text blocks and text with leaders (this is giving me AutoCad vibes).
This in and of itself is a full on project, we may have to take this in stages.
Medeek Engineering
First look at some walls with dimensions added:
I was going to setup an auto-dimension algorithm.  However after building the manual dimension tool I found it so easy to use that I don't really see a reason to bother with auto dimensioning.  What you see here I was able to do in about 2-3 minutes.
Medeek Engineering
I still have some rough edges to work on in the UI but progress is being made:
All dimensions are associative, there is no concept of an orphaned dimension, however I may eventually change my mind on that.  The nice thing about associative dimensions is that when you change the location of a wall or opening all of the dimensions auto-update.
Medeek Engineering
I've added the ability to edit, delete and also move openings in walls from the various elevation views:
Medeek Engineering
I've also added a "visibility reference" icon/tool.  This allows one to not only toggle off the grid but also to toggle on or off the 1st level walls below the 2nd level walls.  This should aid in lining up walls on different levels.
Medeek Engineering
Testing the reference underlays for the Upper Floor Plan (level 1 wall framing and level 2 floor framing):
Medeek Engineering
First look at some complex roofs in the Roof Plan tab:
I will need to stress test it further to see if we can break it.  The solver algorithm is borrowed directly from the new weighted straight skeleton solver I implemented about a month ago in the Truss plugin, no point in reinventing the wheel.
Medeek Engineering
Complex roofs is still a work in progress, no surprise there. The interface will mirror the Truss plugin since we already know how that works. When a roof is selected the "custom" roof planes (edges) will display in red rather than blue. A selected edge will switch to a solid color and the right hand menu will display the settings for that roof plane.
project_su273_800
project_su273_8001753×1046 177 KB
The same settings that are available in the Truss plugin will appear for the selected "roof plane type".
Medeek Engineering
Next is a test of the raised fascia offset:
Medeek Engineering
The user will have the option to use the basic fill colors or the built-in textures.  This feature can be toggled ON or OFF in the Settings.
Medeek Engineering
First look at some exterior trim applied to a couple "test houses".  Corner trim, band board, skirt board and frieze board.
