Wall Plugin for SketchUp
Medeek
Tutorial 76 - Double Stud Walls (18:03 min.)
Nathaniel P. Wilkerson, P.E.
Medeek
Tutorial 77 - Mitek vs. Simpson (11:00 min.)
Medeek
Version 4.1.8 - 12.13.2025
- Fixed a long standing bug where blocking was not created above and below doors, windows and garage doors.
- Fixed the blocking bug for rectangular, gable, shed and hip walls.
- Fixed a context menu bug (Edit Opening...) for gable, shed and hip walls.
Medeek
Version 4.1.9 - 12.16.2025
- Enabled the "Add Studs" feature for the following wall types: rectangular, gable, shed and hip.
Tutorial 79 - Adding Studs (5:31 min.)
Medeek
Version 4.1.9b - 12.18.2025
- Fixed a bug (door presets) introduced with door hardware material update on 11/29/2015 (Version 4.1.5).
Medeek
Version 4.2.0 - 12.22.2025
- Updated the opening and closing algorithm for all (panel) garage doors.
Not a customer request, just an interesting kinematic challenge that I felt like addressing at some point.  I found the previous garage door opening animation largely unsatisfactory for panel doors like these.  Hopefully you can indulge me with a little gold plating... now back to the real stuff.
Medeek Engineering
Version 4.3.3 - 02.08.2026
- Added the following Simpson Strong-Tie anchor bolts to the wall, column and shearwall modules: SABR58-24, SABR34-26, SABR78-28, SABR1-30, SABR114-32.
These new anchor bolts are included in the new Wood Construction Connectors Catalog (C-C-2026) for 2026.
https://www.strongtie.com/bolts_anchorbolts/sabr_bolt/p/sabr
These low poly versions of the anchor bolts are based on the models provided on Simpsons website.
Medeek Engineering
Tutorial 82 - Medeek Wall API (18:43 min.)
I think with all the rapid developments in AI there will begin to be an increase in AI assisted workflows.  We are only seeing the beginning of this.  Honestly, If I don't develop this API I will simply get left behind.  I will need to add in many more methods (ie. draw_door, draw_window, draw_column etc...) I also need to do this for each plugin.
Medeek Engineering
#1008
Version 4.4.4 - 04.02.2026
- Enabled the following methods within the Medeek Wall API: wall_draw_perim
- Enabled "profile cutting" of balusters for vertical and OTP handrails.
I'm not sure why I didn't realize I could do this before but I woke up yesterday and I realized that a simple profile could be revolved into the cutting solid (like putting a piece of square stock on a lathe) and then boolean subtracted from the square baluster as shown to give a typical "turned" baluster.
Medeek Engineering
Version 4.4.5b - 04.08.2026
- Added a tooltip for the Corner Treatment option into the Global Settings, Draw and Edit Wall Menus.
I didn't realize that the term "California Corner" was not well known in the industry.  To that end I've added a tooltip for "Corner Treatment" which shows a typical (2x6) California Corner and a U-Corner.  Hopefully this further clarifies this parameter for some users who are not familiar with this term. The other corner treatments seem fairly self explanatory.
Medeek Engineering
I've been meaning to add in a "Style 6" door hardware option for quite some time.  Basically something for your entrance door, and I haven't had a good option for this until now.  This low poly entrance hardware and deadbolt (handleset) is loosely modeled after the Camelot series by Schlage.  I will include this in the next roll out:
Medeek Engineering
**Version 4.4.6** - 04.11.2026
- Added a "Style 6" (Schlage - Camelot) to the built-in door hardware options.
- Configured the "Ctrl" hot key within the draw door tool with additional justification options (x-dir).
**Tutorial 84** - Positioning Doors (7:19 min.)
Medeek Engineering
Version 4.4.7 - 04.16.2026
- Fixed a bug with custom door positioning for metric templates.
- Enabled "profile cutting" of posts for vertical handrails.
- Fixed a bug with the bottom trimming algorithm for balusters.
Medeek Engineering
Tutorial 85 - Profile Cut Newel Posts (9:04 min.)
Medeek Engineering
Version 4.4.8b - 04.18.2026
- Enabled custom components as balusters for vertical and OTP handrails.
Th sub-folder structure is the same as for newel posts, so Tutorial #85 is applicable to balusters as well.
Medeek Engineering
Version 4.4.8c -  04.19.2026
- Fixed a minor typo in the stair module.
- Added a ornamental iron baluster into the baluster component library.
The limitations of profile cutting balusters can be overcome by using a predefined component instead, which allows for much more intricate baluster geometries.
However as I have been researching various baluster layouts I've noticed that with iron balusters usually more than one baluster style is utilized.  The typical scenario is two or three different baluster geometries are alternated along the run of stairs.  I will need to give this some more thought.
Stairs can be a "rabbit hole".
Medeek Engineering
Version 4.4.9 - 04.19.2026
- Enabled a secondary custom profile/component parameter for balusters.
- Added additional ornamental iron balusters into the baluster component library.
I think I've beat this horse to death.  Hopefully with this added option we can configure most of the common baluster layouts, however there will always be a few that will be beyond the scope of the plugin (ie. three or more baluster types in various repeating patterns).
Medeek Engineering
Version 4.5.0 - 04.20.2026
- Enabled custom components as posts for OTP handrails.
- Enabled "profile cutting" of posts for OTP handrails.
- Modified the bottom trimming algorithm for balusters to better accommodate complex baluster components.
- Added one additional ornamental iron baluster into the baluster component library.
- Added one OTP newel post into the newel post component library: LJ4270_43
I will readily admit configuring OTP handrails with their associated posts and fittings is a bit tricky, adjusting the various offsets takes a few iterations to really hone things in.
Medeek Engineering
Well... I thought I was done with balusters and newel posts, but I'm not quite there yet.
The problem is that with metal or iron balusters they are often installed with a shoe as shown below:
My current algorithm installs balusters just like they are installed in real life:
First I trim the top of the original baluster component/group and then I have to trim them individually for each of their bottoms because the balusters may intersect the treads at different heights hence their heights/lengths will be different.
Because of this a predefined shoe positioned at the base of the baluster component may work for one location (ie. no trimming required) but then it will be removed in subsequent baluster locations.
What this means in practice is that a shoe (if that option were enabled) needs to be a completely separate group/component just as it is in real life.  My algorithm needs to position it individually in the Z-dir just as I trim each baluster bottom individually.
Arguably, there is a lot going on with stairs, the guys that install these must be real craftsmen, I certainly take my hat off to them.
Medeek Engineering
Version 4.5.1 - 04.22.2026
- Enabled custom components as baluster shoes for vertical and OTP handrails.
- Added the following (L.J. Smith) baluster shoes into the baluster shoe component library: LI_ALFSH01, LI_ALR010, LI_ALRD201, LI_ALSQ301, LI_ALSQPL1, LI_PROCOL.
I took the time today to carefully model a few of these baluster shoes since they are fairly simple geometry and it is always fun to get my hands dirty with some actual modeling and take a small break from the code.
Medeek Engineering
Version 4.5.6 - 05.25.2026
- Enabled presets for beams.
- Enabled presets for in-wall columns.
Medeek Engineering
Version 4.5.6b - 05.25.2026
- Enabled presets for stairs.
Medeek Engineering
Version 4.5.7 - 05.26.2026
- Enabled presets for posts.
- Added the following L.J. Smith handrail profiles: 684, LJ6011, LJ6A10.
For those interested I am pulling all of my handrail geometry from LJ Smith's webpage at the following link:
https://www.ljsmith.com/handrails
Medeek Engineering
**Version 4.5.9** - 05.31.2026
- Added two new parameters for elliptical curved stairs into the draw and edit menus: Eccentricity, Clocking.
- Enabled treads, risers and framing (primitive) for curved (elliptical) stairs.
Medeek Engineering
Tutorial 87 - Curved Stairs (9:20 min.)
