Truss Calculators
Medeek Engineering
Here is a simple schematic of a slightly more convoluted roof to try and understand the methodology a bit better:
The two girders in the center of the structure could probably be combined into one larger girder, but maybe it is better to distribute the loads across to trusses instead of one.  The shaded areas are the valley sets or overframing required to fill in the voids.
This design requires 10 main girders and 5 cross girders.  Notice how there is a hip truss at each outside corner and a half valley set at each inside corner.  When to inside corners are symmetric we end up with a full valley set.
Based on these patterns that are emerging I might be able to auto place the girders or at least provide an initial placement which then can be further refined by the user.
Nathaniel P. Wilkerson
Medeek Engineering
Each girder will break up the roof outline into zones.  Then using a combo of boolean subtraction and intersection we should be able to generate this as a starting point:
The blue shaded truss outlines are the girders, the purple shaded are the trusses requiring a further subtraction step to make the correction for the valley truss sets, notice the third purple truss  from the right.
Basically I'm walking you through my algorithm for generating the truss geometry data so I can then draw each truss.  As you can see this is not a trivial process.  Lots of steps and lots of "edge cases" that can potentially trip it up.  That is what I mean when I say the devil is in the details.  However if the basic algorithm is sound one should be able to add in logic to deal with the issues and in the end you end up with a robust piece of code.  These are the kinds of things that keep me up at night.
Based on these slices we should be able to extract the key geometric points that define each truss and then send that data to the separate truss "draw" algorithm which sorts out all the messy details on how to place the webs, plates and all that fun stuff.
Medeek Engineering
Version 3.8.1 - 05.13.2026
- Enabled a second layer of wall sheathing for common and scissor trusses.
- Enabled XPS (blue, green, pink and grey), ISO, EPS, GPS, and PU foam insulation within the wall sheathing and wall sheathing 2 options.
Medeek Engineering
About a week ago I decided it is time to try and port my Truss plugin from SketchUp to Blender.This porting business is tedious work, not exactly fun or interesting. I'm mostly posting on the Blender board about the progress I'm making, but I think I'll post also post here once in a while as well.
Beyond Blender I would really like to see if I can port the extensions into Rhino. Revit may also be an option later on, but I'm really not a huge fan of Revit, I feel like it is a very clunky piece of software.
Here are some screenshots of a common truss with cladding, battens and gutters. It really looks quite similar to what we have in SketchUp with the Truss plugin but under the hood it does have some significant differences.
Medeek Engineering
Here are some other more complex configurations drawn in Blender with the Medeek Truss for Blender: Howe, Fan, Mod Queen, Double Fink.
Medeek Engineering
Medeek Engineering
First look at sheathing, sub-fascia, outlookers and rake boards in Rhino:
Medeek Engineering
He is a first look at gable wall cladding in Rhino:
The Rhino port is slowly coming together.  The goal is to get all of the advanced options enabled for common trusses, then add in the rest of the common truss configurations.  At that point I will probably release the initial 0.9.5 Version (Windows only).  Then, based on the traction I receive in the Rhino community, I will continue to port the rest of the extension over from SketchUp.
Medeek Engineering
First look at some roof returns in Rhino:
Medeek Engineering
I've been speaking to a number of people over the weekend about this port to Rhino. There does seem to be quite a bit more interest and even excitement as compared with my previous port to Blender. I'm actually a bit surprised, I didn't realize there were that many people using Rhino for architecture, who knew?
However, I doubt that there are nearly as many architectural users as there are in SketchUp but I do believe now that the number is not insignificant. To my knowledge Rhino has no integrated 2D drawing system like Layout so I am wondering what is the workflow in Rhino, do they create their drawings in AutoCAD or some other type of CAD environment?
Once this port is complete (maybe in a couple of days), or at least the first public iteration is released, I will be jumping back into my SketchUp code. What I found particularly useful during this entire porting process was the extent to which AI could traverse my code and thoroughly audit it. With those audits I was able to uncover some longstanding bugs and typos that have literally gone undetected for years. AI may prove to be an existential threat but for the time being it is also an excellent proof reader.
