siding and window trim
Started by dug, November 16, 2011, 09:25:05 AM
dug
My vinyl window frames protrude about 1 and 1/2 inch from the exterior sheathing and the tongue and groove siding I am installing is 3/4 inch V-groove. I was originally planning to trim around the windows using the same 3/4 inch material but now I realize that if I did that the trim would end up flush, or maybe even extend beyond the vinyl window frame. I think you would want the window frame to extend at least 1/2 inch out from the trim, especially at the bottom sill or water would drip off and get behind the wood.
Three options I have thought of-
1-  Trim with 1 inch material first and butt siding to it
2-  Really thin trim, 1/4 or 3/8 inch (don't much like this option)
3-  No trim, butt siding to window frame.
Any suggestions?
walkabout
I went with 5/4 (one inch) Miratec (but you could use natural wood too) to give a boxed look and liked it.
basically it is like this:
All interestions were caulked. i.e between siding and trim and also between trim and window.
ditto walabout.
Install 5/4 trim first. Then the siding. Leave a slight gap between siding and trim for expansion. Clear caulk the joint.
