Lost my photobucket pix
Started by mpls_ham, June 28, 2011, 01:40:36 PM
mpls_ham
Hi Don,
I lost all my project photo links due to sorting of photo albums (wifey).  Can I re-route the photos or do I have to start over.
mpls_ham
Northern Black Hills - South Dakota
mpls_ham  Don may be still on his mountain.  If you right click on the previous image ( Box w/photobrucket ) you can go to properties.  That will at least tell you which picture it is.  Then go back through your thread and modify the post which have photos.  Delete the old link for the picture and insert the new one in it's place.  Might be time consuming but I have done this before.
That's about what has to be done. Click on the modify link at top right of every message of your own. You can change the link. Just takes time/effort.
mpls_ham
I am not seeing a modify link at the top?
If you are logged in as a member you should see something like this...
You will not see the "modify" if you look at any other persons posted messages. If you ever had 2 different accounts here you will only see the "modify" on the account you are logged in to.
If you will look just above the message window on your original post to the right there should be three catagories. Quote, Modify and remove.  Just click the modify and the original message will now appear in the message window and allow you to change, delete portions or remove the complete post all together.  When other view your post they will just have the option of "quote" visible.  They cannot modify or remove your post only moderators or those sitting high on the throne can do this. ;D
Darn Don you beat me to the draw by seconds. ;)
mpls_ham
Thanks guys.  The Modify selection magically appeared. [cool]
