Changed: 10 x 12 with Loft Storage Shed in NW Wisconsin (Spooner Area)
Started by duncanshannon, June 11, 2011, 08:16:27 PM
UperJoe
Quote from: CjAl on September 23, 2011, 04:20:44 PM
Nowhere else has better woods then WI. im a wi native now in east tx.
That septic shstem is the.main reason i.sold my place in wi. Mine was getting weak and i couldnt afford a super mound. Plus wi has turned into suck a nanny.state i.couldnt deal with them any longer. I almost got taken to court because i put a circle drive in and they freaked.out over two access points to the road instead of one.
Now i have no buildiing codes, septic cost $2300 installed and you can still afford lakefront property here. But i sure do miss wi summers.
That is the whole reason I sold 7 acres near Hayward ....... I felt like the things were taken over by the County Gestapo types. Crazy ....
Now working on a parcel up in the UP and seems they pretty lenient or at least reasonable and use common sense vs the "interpreted code" I found in WI and MN where I still have my home
