Author Topic: Okanogan 14x24 by a lurker :)  (Read 843172 times)
Offline OlJarhead
    • Team SEWA
Re: Okanogan 14x24 by a lurker :)
« Reply #2800 on: June 08, 2017, 04:47:06 AM »
Oh let's be honest!  Those guys are serious pros!  I put my heater in just because it's unique but it isn't anything like the stuff some guys have built ;)
Still, it's cool so I hope to get some good vote counts ;)
Offline Adam Roby
  • Montreal, Canada
« Reply #2801 on: June 08, 2017, 04:52:31 PM »
You got my vote already...  :)
Offline OlJarhead
    • Team SEWA
« Reply #2802 on: June 08, 2017, 06:37:07 PM »
Thanks guys!  Raining at the cabin but that means a food might for a book and a drink ;)
Offline Tickhill
  • Look up ^
« Reply #2803 on: June 09, 2017, 02:52:05 AM »
I put my 2 cents in for you!
Tickhill
"You will find the key to success under the alarm clock"  Ben Franklin
Offline OlJarhead
    • Team SEWA
« Reply #2804 on: June 09, 2017, 03:41:25 AM »
At he cabin this weekend. Started early due to work so was able to check on the orchard and do a little cleanup before my honey arrives today.  We're going to burn slash and clean the place up since it's in dire need.
The fruit trees seem to be doing well and the last surviving apple blossomed this spring!  Hopefully it won't take 5 years before the new ones I planted do but if it does, oh well.  Not much I can do now since the gophers killed the other 4 apples I had.
Now we have solar gopher repellers in the orchard and they seem to be doing the trick.
I also picked up a pair of white roofing panels (the plastic type) to mount over the solar heater for the winter.  The next step on this one is to make it permanent but I've not had much time out here to do much with it yet.  So, hopefully I can take a weekend a month to work on that, put up the solar panels and a few more projects I wish to get done this year.
Offline OlJarhead
    • Team SEWA
« Reply #2805 on: June 09, 2017, 01:05:44 PM »
This is the result of the temp logger left in the porch just above the batteries.
Nights were in the 30's and the porch is not well insulated (nothing in the floor or ceiling and some of the wall space not insulated).  With day time temps mostly in the 60's with the occasional reach into the low 70's the cabin porch hit over 90F several times.  Night temps down in the 30's didn't matter much as the heater warmed the room significantly enough to allow for the drop in temps outside leaving the porch as much as 20F warmer than outside air temps.
I'm shutting it off this weekend but plan to see what the porch does without it to compare.  However, I am VERY impressed with this heater!
« Last Edit: July 26, 2017, 03:42:50 AM by OlJarhead »
Offline OlJarhead
    • Team SEWA
« Reply #2806 on: June 12, 2017, 04:16:21 AM »
A few pics from this weekend :)  We burned slash, picked up trash, installed new funny pipe in the orchard to provide water to the trees and generally relaxed and enjoyed the weekend :)  Hope is to return again soon to get more done but I've injured my shoulder running the mill recently so am trying to take it easy until it recovers.
« Last Edit: July 26, 2017, 03:42:39 AM by OlJarhead »
Offline JavaMan
  • Rock Of Ages Ranch - Somewhere in the Okanogan
    • The Lodge at Rock Of Ages Ranch
« Reply #2807 on: June 18, 2017, 08:16:41 PM »
Still raining up that way? wow - I think it's been a very wet summer so far.
Injured your shoulder? Well, take it easy as I am pushing my milling needs back a few weeks ;) ... just have not been able to get up there as often as I'd like... hoping to fix that, tho.
Your place looks awesome all greened out like that!
Offline OlJarhead
    • Team SEWA
« Reply #2808 on: July 06, 2017, 07:06:39 AM »
Seems photobucket is toast these days.  Need to find a new place to host (or make my own).
Got my white roofing over my solar heater so that should help with keeping the heat down this summer.  Thing is at 65 degrees and still puts out a LOT of heat!
Offline navybobunderway
  • Apprentice
  • Welcome to the CP-Forum
« Reply #2809 on: July 12, 2017, 05:39:47 AM »
OK Jarhead, this thread is wicked long, but I'm working on catching up. Seems like we are practically neighbors as soon as we start building........
Thanks for chiming in on our thread as well. I'm with you, spent the weekend in Omak a couple back, and being on Whidbey for the last 10 years or so
has done NOTHING for my ability to handle anything like real heat.....it was definitely "warm" while we were shopping parcels.
Offline JavaMan
« Reply #2810 on: July 12, 2017, 09:25:31 AM »
Welcome to the neighborhood, NavyBob!  I'm building up in Okanogan as well! Always good to see a new neighbor.
OJH ... how's your injury healing?  I hope it hasn't slowed you down much.
Offline OlJarhead
    • Team SEWA
« Reply #2811 on: July 13, 2017, 07:53:23 AM »
Hard to say Java.  It's healing but slowly and I'll know better this weekend as I am remote milling in Mazama
Offline JavaMan
« Reply #2812 on: July 14, 2017, 08:58:00 AM »
No rush  OJH ... Just was hoping you were on the mend!  I've managed to fall behind.  I've moved closer to the ranch, and am currently in the Ellensburg area
Should shorten the drive to teh property immensly!
Offline OlJarhead
    • Team SEWA
« Reply #2813 on: July 19, 2017, 03:13:20 PM »
Please note, I have deleted my photobucket accounts.  They just got too ridiculous.  Sorry!
Offline Toyotaboy
  • Junior Member
« Reply #2814 on: July 20, 2017, 04:09:16 AM »
I saw all my stuff went belly up with Photo bucket too.
What recommendations for a host now?
Offline azgreg
  • Full Member
« Reply #2815 on: July 20, 2017, 05:15:49 AM »
I'm using postimage right now. So far so good.
https://postimages.org/
Offline OlJarhead
    • Team SEWA
« Reply #2816 on: July 26, 2017, 03:42:15 AM »
I'm updating my own site (dartplayer.net and sewa-darts.com) to add a gallery and will just host my own ;)
  • Apprentice
« Reply #2817 on: July 27, 2017, 08:04:50 PM »
So I replied in my post, but real question is, how much for milled lumber? Not super familiar with rough cut, but learning....also asked about equipment operators, shopping a loader/backhoe, and or tractor, but maybe a local with the gear is money well spent. We have 20 acres, like to "tame" about 5 of it....it's sloping, but not awful....
Offline OlJarhead
    • Team SEWA
« Reply #2818 on: August 01, 2017, 10:32:56 AM »
Milling runs anywhere from $250/Mbf to $500/Mbf depending on where you are etc.  I charge by the hour for remote milling ($85/hr) which falls within that price range (to get down around $250 you have to have good logs, site and help).
If in the Okanogan I can recommend a couple fallers that are young and hard working but I don't know how available they are as they both fight fires too.
  • Apprentice
« Reply #2819 on: August 02, 2017, 02:50:03 PM »
Hey thanks for the reply, we don't have a lot of trees for felling, was more wondering if you have rough cut for sale?
Offline OlJarhead
    • Team SEWA
« Reply #2820 on: August 03, 2017, 08:52:30 AM »
Nope sorry!
Offline OlJarhead
    • Team SEWA
« Reply #2821 on: September 11, 2017, 11:05:46 AM »
Soon heading back up to the cabin for a short visit.  I do a fair amount of overnighters at the cabin since moving down south as I still maintain an office in Omak.  This trip, like most, I'll try to get a little work done and a little relaxing :)
Offline OlJarhead
    • Team SEWA
« Reply #2822 on: September 26, 2017, 03:15:13 PM »
So I finally pulled the plug and bought the battery fan and relay for my battery bank :)  I chose the relay even though I will be installing an outback charge controller (which I bought last year for the 6 panels I bought) because I can get it up and running sooner with this relay than if I waited.
Now, the next phase of my solar improvements is the following (at least these are my thoughts and I am looking for feedback):
1.  Move the inverter and charge controllers inside the cabin (just inside the wall instead of in the porch above the batteries
2.  Once the inverter and charge controllers are inside the cabin (where they will be warmer, less dusty and no longer near the batteries) I will complete the battery box around the batteries and install the fan and relay.
3.  Move the Trimetric battery monitor inside the cabin
4.  Consider getting a second monitor or just a voltmeter for the porch so I can see where the batteries are when I arrive and before entering the cabin (my preferance).
5.  Install a 12v or 24v porch light inside and outside the porch (today I turn on the power and the light comes on as it's left on when I am gone (switch is inside) so it will come on when I turn on the power.
One thing I need to research is the right cable size for the inverter.  It's a 4000w pure sine inverter that can peak at 12000w and has a 50amp charger built into it (24v).  I have been using the same cables (2-0 if I remember right) from when I built the system as a 12v system.  I'm thinking I can stick with 2-0 and install 36" cables from the batteries to the disconnect and inverter (disconnect will remain in the porch at this time).  The cables I have now are too stiff so I'm looking at ordering a set of these (or similar): https://www.solarpanelstore.com/solar-power/wire/inverter-cables/ul00black36.html
I will cut down the copper buss bars to a much smaller bar and tie the batteries all to the bar at the same point (instead of seperating them the way I did before) thereby reducing uneven usage (however small) and less room required for the bus).
I'll still have to decide if I want to leave the auto-gen switch and 24v-12v converter in the porch or move inside (don't have much room but thought it would be better to have the inverter, at least, inside if not also the controllers).
Then I'll need to start working on the 'command' center where my controls and meter will reside (near my chair by the wood stove has been the plan).
Thoughts?
Offline OlJarhead
    • Team SEWA
« Reply #2823 on: September 26, 2017, 04:08:40 PM »
Aims manual says 1/0 for the 4000watt inverter when 24v and up to 3 meters.  So if I go 3 feet I will be Good!  Now just need to check lengths I need before ordering the flex cable I want
Offline OlJarhead
    • Team SEWA
« Reply #2824 on: October 01, 2017, 01:37:11 PM »
Meanwhile in the woods somewhere other than my cabin ;)
