Author Topic: Builders cottage  (Read 2843 times)
Offline cedarglen
  • Full Member
  • I love YaBB 1G - SP1!
Builders cottage
« on: August 06, 2005, 09:08:40 AM »
I am back and forth on plan choice, it will be hard to fit the Victoria cottage on my pad. I want to squeeze as much house as possible into a very small space (my pad is about 17x30).
I see the Big Enchilada description mentions that there are details for the  Builders Cottage with high side walls, for a functioning bedroom upstars. Can I get a little more info on that? How much headroom? Is there a short (like 2') wall upstars or do the rafters touch the floor? I assume that  the bedroom can be extended all the way across the house?
thank you,
Charles
trish2
  • Guest
Re: Builders cottage
« Reply #1 on: August 06, 2005, 01:41:45 PM »
If you are pad restricted, there is always the possiblity of overhanging/cantelever some of the top of the structure to gain a foot or two.  We had a thread on that a while back, so if you check the archieves you might get some usable ideas for your particular situation.
Offline Leo
  • Full Member
« Reply #2 on: August 08, 2005, 01:33:01 PM »
I to went back and forth on those two designs,the extra two feet of width makes a big difference .13 feet versus 15 on the inside,16'is a common lenght for lumber and its 4 sheets of plywood wide,much better for stairs eytc . etc .also a bathroom and kitchen can be worked into one end easily
Cache hits: 11: 0.00119s for 40,725 bytes (show)
Queries used: 28.
