Useful Simpson Bracket I Just Discovered
Started by MountainDon, May 15, 2009, 10:48:08 AM
Picking up some items last night at Lowe's I discovered a Simpson bracket I never knew existed.
It's the BCS Post Cap. The BCS allows for the connection of 2-2x's to a 4x post (BCS2-2/4) or 3-2x's to a 6x post (BCS2-3/6) , without using spacers or fillers.
http://www.strongtie.com/products/connectors/BC.asp
devildog
M.D. is the plywood needed for strength on johns plans or is it a filler?
While the plywood likely does add some stiffness, I do not think the calculations consider the plywood. I might be wrong on that.  ???
I am going to use those when I construct the cabin battery box and the porch.
Okie_Bob
Thanks Don, that is a good one I didn't know about either!
hnash53
#4
That's the one I used in the above pic.  Works great.
http://www.countryplans.com/nash.html#Ladder
