Author Topic: Footing drain tile pipe???  (Read 2819 times)
Offline 2zwudz
  • Junior Member
  • CountryPlans member
« on: May 12, 2008, 05:10:00 PM »
   What type of drain pipe do you like to use as a footing drain tile, the regular pipe with drain holes in it or the one with drain holes and the sock?
Mark
Offline glenn kangiser
  • The Troglodyte
    • Underground Cabin
Re: Footing drain tile pipe???
« Reply #1 on: May 12, 2008, 07:23:12 PM »
I like the sock.  Some say they don't even need rock with the sock - hey that rhymes d* -- but I like rock too.
Offline Willy
  • Fighting Wildland Fires for a Living! Okanogan, WA
« Reply #2 on: May 12, 2008, 07:41:49 PM »
They say the sock is better because it keeps the silt out of the pipe. If I was to put in a footing drain I would bring one end up to grade so it could be washed clean once in a while. Mark
  • The Troglodyte
    • Underground Cabin
« Reply #3 on: May 12, 2008, 08:01:30 PM »
That could be a good idea - washout on the high end with the low end draining down hill to daylight.
Offline BiggKidd
« Reply #4 on: May 13, 2008, 03:59:53 AM »
Hi Guys,
  The sock is the way to go unless you are not using stone and have a very fine clay. I have seen the sock get stopped up in under a month direct burried in fine clay. The sock was like concrete with the fines stuck in it.
Larry
 Larry
  • The Troglodyte
    • Underground Cabin
« Reply #5 on: May 13, 2008, 04:43:15 AM »
Thanks, Larry.  Thats how I pictured it happening, but their advertising didn't mention it.
Offline BiggKidd
« Reply #6 on: May 13, 2008, 04:48:39 AM »
 They never do d*
Larry
 Larry
Cache hits: 12: 0.00235s for 40,787 bytes (show)
Queries used: 29.
