Templates: 5:
index (default),
Ads (default),
Portal (default),
Display (default),
GenericControls (default).
Sub templates: 12:
init,
html_above,
adsheaders_above,
body_above,
adsindex_above,
portal_above,
main,
portal_below,
adsindex_below,
body_below,
adsheaders_below,
html_below.
Language files: 3:
SPortal.english (default),
index+Modifications.english (default),
Ads.english (default).
Style sheets: 1:
portal (default).
Files included: 38 - 1132KB. (
show./index.php, ./Settings.php, ./Sources/QueryString.php, ./Sources/Subs.php, ./Sources/Errors.php, ./Sources/Load.php, ./Sources/AnnoyUser.php, ./Sources/Subs-Portal.php, ./Sources/Security.php, ./Sources/LoadAds.php, ./Sources/Subs-Db-mysql.php, ./cache/data_31251d04c554214991bc2f70ab5edbfe-SMF-modSettings.php, ./Sources/ManageSearchEngines.php, ./cache/data_31251d04c554214991bc2f70ab5edbfe-SMF-spider_search.php, ./cache/data_31251d04c554214991bc2f70ab5edbfe-SMF-board_parents-0.php, ./cache/data_31251d04c554214991bc2f70ab5edbfe-SMF-permissions--1.php, ./Sources/Subs-Auth.php, ./cache/data_31251d04c554214991bc2f70ab5edbfe-SMF-theme_settings-1.php, ./Themes/default/languages/SPortal.english.php, ./Themes/default/index.template.php, ./Themes/default/languages/index.english.php, ./Themes/default/languages/Modifications.english.php, ./Themes/default/Ads.template.php, ./Themes/default/languages/Ads.english.php, ./cache/data_31251d04c554214991bc2f70ab5edbfe-SMF-log_online-update.php, ./Sources/PortalBlocks.php, ./SSI.php, ./Themes/default/Portal.template.php, ./Sources/Display.php, ./Themes/default/Display.template.php, ./Sources/Subs-Editor.php, ./Themes/default/GenericControls.template.php, ./cache/data_31251d04c554214991bc2f70ab5edbfe-SMF-verificationQuestionIds.php, ./cache/data_31251d04c554214991bc2f70ab5edbfe-SMF-parsing_smileys.php, ./Sources/AutoEmbedMediaPro2.php, ./cache/mediaprocache.php, ./cache/data_31251d04c554214991bc2f70ab5edbfe-SMF-response_prefix.php, ./cache/data_31251d04c554214991bc2f70ab5edbfe-SMF-moderator_group_info.php)
Cache hits: 12: 0.00119s for 40,832 bytes (
showget modSettings: 0.00025s - 15639 bytes, put modSettings: 0.00021s - 15639 bytes, get spider_search: 0.00006s - 1882 bytes, get board_parents-0: 0.00007s - 6 bytes, get permissions:-1: 0.00006s - 75 bytes, get theme_settings-1: 0.00007s - 2017 bytes, get log_online-update: 0.00007s - 0 bytes, get verificationQuestionIds: 0.00011s - 18 bytes, get parsing_smileys: 0.00009s - 5427 bytes, get response_prefix: 0.00010s - 11 bytes, get moderator_group_info: 0.00007s - 118 bytes, get menu_buttons--1-english-1: 0.00002s - 0 bytes)
Queries used: 29.
