Question about filling void between outer wall and drywall
Started by gradygodfrey, July 22, 2024, 02:12:09 AM
gradygodfrey
Hello,
I have a gap of about 40x5 inches between the outer wall of my house and the drywall inside. I'd like to block it up as we're in that time of year when mice may crawl in and get in the house. The filler foam was unsuccessful, so I was thinking of blocking it up with some wood and then using filler foam around any gaps to truly seal it up.
Would this be the beat course of action, or am I missing something better? Would getting some insulation cut to fit be a better solution, or something else?
Thanks in advance!
Have you considered galvanized welded wire fabric?  1/4" should keep most varmits out.  For insects, one would need to add a covering of window screen fabric.  Seal joints with a roofing style black polyurethane sealant .. I like Loctite in cauking tube.
